Monster MotorsportBadger5
    Feb 2014
    Nottingham
    Alarm/Central locking problem.
    Evening all,
    new here for firstly hello! just recently bagged myself a bargain off eBay, Got a 8L (sadly only a 1.6 but insurance is high for me) taxed M.O.T'd 115K on the clock with a belt and pump change at 84K for £540 So naturally I expected their to be a few issues.
    luckily most of the issues have been sorted ( Diff went after a few weeks, wheel bearing ) and now I have a problem with the alarm,
    when scanned with VCDS I was getting a error code showing no communication with the alarm. went down to my local Audi breakers and got a replacement module for £10
    fitted it this afternoon and works great, but after a hour or two, the alarm started going off randomly, and the key fob wouldn't work?
    have I missed something out when fitting the alarm i.e syncing of some sort with VCDS or could I have got a incorrect module which is causing a issue with the central locking?
    thanks in advance
    Oct 2010
    Hampshire
    294
    The alarm siren has its own backup battery inside it so that the alarm can still function if the car battery is disconnected. When the sirens get old these battery's no longer hold their charge and end up setting the alarm off when the voltage drops. Some people then disconnect the siren and remove altogether. There are a few threads that show you how to replace the internal batteries. A few years back i remember a new siren was about £80 and i decided not to replace mine.
  1. alarm central locking problem
    By teknik in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2011, 20:42
  2. Alarm/ central locking problems on 99 B5
    By B5_Avant_AAN_Powered in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2010, 19:52
  3. Central Locking Problem - Remote Alarm
    By brettfk in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th November 2009, 08:25
  4. Remote central locking problem!someone please help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:43
  5. a4 central locking problem
    By imported_stunt_man_rob in forum General Technical / How To
    Last Post: 23rd June 2004, 22:10
Tags for this Thread
