Chris NottSky Insurance
    May 2003
    Reading
    705
    Dash Illumination
    I think I've seen this on here before but can't seem to find it using search.
    What and how exactly do I need to change with VAG-COM so that the dash needles on my 2001 1.8T are on all the time?
    Is there anything else I can change easily?
    TIA
    PaulS3's Avatar
    UK
    988
    Re: Dash Illumination
    TT procedure below.
    No idea if it bears any resemblance to your car.
    so make note of anything before changes, all at your won risk
    http://www.wak-tt.com/vagcom/vagcomdashillum.htm
    May 2003
    Reading
    705
    Anyone know if this will work on the A3?
    Otherwise it looks like I'm going to have to try it tonight.
    May 2003
    Reading
    705
    I went out and tested the above link but it doesn't work on the A3, channel 19 comes up as not available in VAG-COM. I have a different instrument cluster than the TT my model is a AB-KOMBIINSTR VDO D12. I did go through each channel nd make a note of what it was set to with the list below:
    Adaption Channel Value Description
    1 Not Available
    2 0
    3 100 Consumption Indicator
    4 2 Language
    5 Not Available
    6 Not Available
    7 Not Available
    8 Not Available
    9 4365 Mileage in 10's
    10 Not Available
    11 Not Available
    12 Not Available
    13 Not Available
    14 Not Available
    15 Not Available
    16 Not Available
    17 Not Available
    18 0
    19 Not Available
    20 Not Available
    21 4 Old Key count
    22 Not Available
    23 Not Available
    24 Not Available
    25 Not Available
    26 Not Available
    27 Not Available
    28 Not Available
    29 Not Available
    30 128 Tank Sensor
    31 Not Available
    32 0
    33 Not Available
    34 Not Available
    35 0
    36 Not Available
    37 Not Available
    38 Not Available
    39 Not Available
    40 162 Insp in 100 miles
    41 526 Insp in 1 days
    42 9 Min oil in 1000 miles
    43 19 Max value Oil in 1000 miles
    44 730 Max Value Insp in 1 days
    45 2 Oil quality
    46 931 Oil Consumption in 1 liter
    47 Not Available
    48 Not Available
    49 Not Available
    50 Not Available
    51 Not Available
    52 Not Available
    53 Not Available
    54 Not Available
    55 Not Available
    56 Not Available
    57 Not Available
    58 Not Available
    59 Not Available
    60 1025
    61 0
    62 0
    63 Not Available
    64 Not Available
    65 Not Available
    66 Not Available
    67 Not Available
    68 Not Available
    69 Not Available
    70 Not Available
    71 Not Available
    72 Not Available
    73 Not Available
    74 Not Available
    75 Not Available
    76 Not Available
    77 Not Available
    78 Not Available
    79 Not Available
    80 Not Available
    81 Not Available
    82 Not Available
    83 Not Available
    84 Not Available
    85 Not Available
    86 Not Available
    87 Not Available
    88 Not Available
    89 Not Available
    90 Not Available
    91 Not Available
    92 Not Available
    93 Not Available
    94 Not Available
    95 Not Available
    96 Not Available
    97 Not Available
    98 Not Available
    99 Not Available
    Does anybody know what I need to change in the list above to enable the needle to be lit all the time? Or if it is even possible in the A3?
    Aug 2003
    Spain
    66
    only 2002 on upwards clusters
    Audi A3 S3
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    my w reg S3 (2000) are on all the time is this because its an S3?
