Monster MotorsportChris Nott
Results 1 to 13 of 13
    Feb 2006
    Bucks, England
    39
    Help regarding outside temp readout
    As I am new to this forum, I thought I would start off with prossibly a stupid question.
    When I got back in my 2001 (210) S3 today after having driven it only and hour ago, I looked at my out side temp reading and noticed it was at +16c. (outside temp was actaully +2 at the most)
    Anyways, while driving I kept monitoring it and it slowly made its way back down to about +1.5.
    I dont know if the +16 was due to the car still being warm from driving it before but i have never noticed this happening before so would like to know if anyone has ever had this problem and what the cause may be.
    Please help. Thanks
    darnich's Avatar
    Aug 2005
    North Greece
    106
    Re: Help regarding outside temp readout
    Welcome mate
    Make sure the outside temp sensor is securly held in its place.If it has fallen towards the engine compartment it will read higher temps due to the engine heat.
    In my car (prefacelift LHD A3) is located in the lower right hand side of the front bumber as you look the car from the outside.
    Feb 2006
    Bucks, England
    39
    Cheers,
    I will have a look tomorrow.
    darko's Avatar
    Dec 2004
    london, uk
    272
    mine has been doing this for ages - i was going to replace the sensor but hadnt thought o check its position ! what does the sensor look like ?
    darko's Avatar
    Dec 2004
    london, uk
    272
    did you sort this one out ? does anyone have a diagram of the sensor position please ?
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    I've been getting this for ages too. Temp reading always returns to correct level after driving for about 2 mins or so....
    Sounds like another common one!!
    imported_monkeytrousers
    It's normal for the temp to read higher after standing between drives, it's even mentioned in the handbook.
    darko's Avatar
    Dec 2004
    london, uk
    272
    mine is ok the first time i drive the car in the morning or whenever but if i stop somewhere and then get back in and drive the temp reads way too high - thought it was 18C about 30 mins ago - I wish !!
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    [ QUOTE ]
    [/ QUOTE ]
    This could just be heat soak from the engine, remember it'll get hot under the bonnet and stay hot for a long while, that said my S3 doesn't seem to have the same problem.
    darko's Avatar
    Dec 2004
    london, uk
    272
    that would seem likely to be the problem however mine also didnt always do this (started about 6 months ago) so maybe the sensor has moved from wher it is supposed to be - does anyone have a diagram so that we can check ?
    darnich's Avatar
    Aug 2005
    North Greece
    106
    Here is a picture that shows the temp probe location on the prefacelift model,
    sorry but I dont have a more appropriate photo.
    If the probe is not held in its place then it will not be accurate once the engine is hot.
    However you should be able to locate it and push/lock it back in its place easily.
    darko's Avatar
    Dec 2004
    london, uk
    272
    great - thanks, a good job for this weekend i think !
    darnich's Avatar
    Aug 2005
    North Greece
    106
    its probably only a 5min job though [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Hope you'll sort it out
