Chris NottEM Tuning
    Midlands
    270
    Getting rear caliper dust seal back in
    Hi
    When I wound the pistons back in for new pads I noticed one of the dust seals had came out.
    How do I get it back in ?
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    Oct 2012
    234
    It's a bit of a fiddle! If I remember correctly you have to get the seal seated inside calliper before stretching the seal over the piston. There's probably a tutorial on YouTube of how to do it.
    Oct 2012
    234
    Ill elaborate a bit on that as that's a bit vague... Pretty sure this is how I did it... Fit the seal inside the caliper, then using some brake fluid to lubricate the seal and piston use a couple of screw drivers to lever the boot over the piston. Then it can be slid in until you can seat the boot in the undercut on the piston.
    Midlands
    270
    It's getting the seal inside the caliper that I couldn't do
    Dave
    Oct 2012
    234
    Did you have the seal already over the piston? If so its pretty much impossible to do!
    Make sure the undercut in the caliper is clean as they can crap in the corners. It should seat in there fairly easily. Then once youve done that you have to carefully lever it over the piston, making sure not to pull it as its easy to pull it out of the caliper.
    Midlands
    270
    Yes, it's on piston.
    The piston sticks out the caliper, which now sounds like the problem, ie it needs to be wound in further before I attempt it.
    Dave
  1. any posts / how tos to replace the seals on rear calipers?
    By epox in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2013, 22:41
  2. Winding back S3 rear calipers
    By Jonesymk2 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2012, 17:42
  3. Pushing back rear caliper pistons?
    By Jonay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd October 2010, 23:59
  4. R32 rear calipers
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2005, 10:17
  5. Audi 80 Girling Rear Calipers
    By Geewiz in forum Handling
    Last Post: 12th June 2005, 15:37
