AH FabricationsEM Tuning
Like Tree1Likes
  • 1 Post By epox
Thread: ?? air temp sensors difference air temp and intake temp
    epox's Avatar
    Oct 2012
    Glasgow
    584
    hi peeps,
    i was logging the car the other day and noticed there was a big differance between the air temp reading and the intake temp.
    i thought the intake temp would be much closer to or lower than the outside air temp.
    what the norm if there is one.
    thanks
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,558
    Intakes temps will always have the potential to be higher than ambient as it gets heated by the turbo (compression of air generates heat) and general under bonnet temps... this is why turbo engines have intercoolers to manage heat... a decent intercooler will normally cool charge air to 10/15 degrees above ambient... the std side mounts are prone to heat soak and will end up getting hotter and hotter
    Only time I have seen IAT's the same or lower than ambient is with WMI
    <tuffty/>
    epox's Avatar
    Oct 2012
    Glasgow
    584
    Thanks for the reply.. strange the things you think of when the wife has emmerdale on!!
    <tuffty/> likes this.
  1. BKD A3 TDI MAF sensor differences between 2004 and 2011 0281002461 & 0281002735
    By Matt_Storm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2013, 13:53
  2. Air Mass sensor Low Signal errors and main dealer
    By bertybassett in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2012, 07:56
  3. Intake air temp sensor
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 15:42
  4. intake air temp. sensor problems
    By routers77 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2010, 12:48
  5. Air Mass Meter and Coolant Temp. Sensor
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2008, 20:29
