Sky InsuranceBadger5
    Oct 2013
    41
    195/50 R15 On Pepperpots?! Possible?
    Hi,
    I'm just weighing up options here, and as always I'm on a budget.
    I have 15" pepper-pots which will soon need some new rubber, Current tyre size is 195/65 R15.
    I was always fond of the Yokohama parade spec2 as I've had them on previous cars and wanted to purchase the same for the A3.
    The yokohama's are 195/50 R15's and don't seem to come in any other form for a 15" wheel.
    Am I being ridiculous in asking whether I could getaway with fitting the Paradas on the Pepperpots? I know they'll physically fit, but to what effects?
    Oct 2012
    238
    Your speedo will read slightly faster than your actual speed, but other than that it'll be 'reet!
    Oct 2013
    41
    In terms of diameter, how much smaller will the Paradas be? Is this a substantial change in size or am I over thinking this?
    I guess this will also have a knock on effect with the mpg being less.
    I think I would welcome the speedo to be a little bit ahead.
    Oct 2012
    238
    Got this from Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit...
    Speedo error 10.16%
    Reading at 30mph 33.05mph
    Reading at 60mph 66.09mph
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    It is really quite a big change, more so than I'd be happy with personally.
    My Scirocco runs 195/50R15's with a 1.8t Audi A3 gearbox, and the gearing's pretty low, it's sat at 3.5k at 70 which does hurt the economy and get a bit boring on long runs. I'm on the look out for a diesel box to correct this, but that's because my car/arches won't fit larger tyres. I can't comment on the speedo error as mine's corrected for the wheels, but the theory's sound that it'll be 10% out.
    In your shoes I'd just stick to the correct sized tyres (and I'm no originality obsessive!). There's plenty of tyres out there as good as the Pradas, they're a decent enough tyre, but there are other choices that match their performance easily enough. As well as the speedo issue, you'll also loose 30mm of ground clearance and the car will look really odd with a massive gap in the wheel arch.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
  1. Possible New Group Buy - Look!
    By Moresauce in forum General Chat
    Last Post: 17th November 2003, 11:31
  2. Looking to get Xenons (possibly BI XENONS)
    By nagges187 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2003, 20:37
  3. Possible RS3 in this Weeks Autocar
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 13:50
  4. computer boffins, is it possible to......
    By ooooaudi in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 25th February 2003, 19:55
