Sky InsuranceChris Nott
Results 1 to 20 of 20
    robthehungrymonkey's Avatar
    Apr 2004
    Uckfield, Near Brighton
    555
    Quick question - legal tyre tread?
    Is the legal tyre tread 1.6mm?
    Just checking that i need 4 and not two new tyres!
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Quick question - legal tyre tread?
    just use the wear indicators on the tyres!
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    like rich says if the wear indicators are showing / level with the tread on more than just the very outside or inside you need new ones, infact probably before but that's when they'll be illegal.
    imported_alecblack
    Rich,
    I know this sounds dumb but what is
    the tyre wear indicator? what does it
    look like. I have looked for this before but i didnt really know what
    i was looking for.
    PaulS3's Avatar
    UK
    988
    little bumps in the tread grooves.
    Apr 2004
    555
    Might sound stupid, but I couldn't actually see any earlier today!
    Either that's really bad, and they've worn way to far! Or i'm just being stupid (i expect the latter!).
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    I thought that the legal limit was 1.6mm but I've always used 2mm as a rough guide as tyres can wear unevenly.
    Jun 2004
    Crowthorne, England
    2,512
    For you guys trying to find them they should also be indicated on the sidewall of the tyre with an arrow or some such rubbish then you just need to look across the tread for either raised patches deep in the tread on new ish tyres or a flat spot connecting the tread blocks together across the tyre in very worn illegal tyres.
    If in real doubt pop down halfrauds and by a tread depth gauge ~ 7 from memory.
    Oct 2003
    South Wales
    2,942
    Yes 1.6mm
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Yes the legal limit on car tyres is 1.6mm but I always change mine at 2mm
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    1.6mm for cars
    1.0mm for motorbikes
    and visible tread for mopeds/scooter!
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    [ QUOTE ]
    [/ QUOTE ]
    At least 1.6mm throughout a continuous band in the centre of the tread and around the entire circumference ( the edge's can be bald [img]/ubbthreads/images/graemlins/shocked.gif[/img])
    and the wear indicators are 2mm on most new tyre now
    imported_gek
    Don't some tyres make an audible whine when they are down to the legal limit? Obviously while moving!
    I thought the Eagle F1s did this?
    PaulS3's Avatar
    UK
    988
    my good years are noisy but still legal. (still up off the tread wear guides)
    ill be glad to get rid of them
    darnich's Avatar
    Aug 2005
    North Greece
    106
    Goodyear Eagle F1s are noisy anyway
    darnich's Avatar
    Aug 2005
    North Greece
    106
    here you can read all about it:
    www.2pass.co.uk/tyres.htm
    ...Watching you!
    Earlsfield, London
    5,087
    just run your finger through the grooves on the tyre and you will come across one eventually.
    RIch
    PaulS3's Avatar
    UK
    988
    [ QUOTE ]
    [/ QUOTE ]
    true, even goodyear admitted that.
    But mine seem to be getting worse. road noise has been on the increase recently.
    They are comming up to replacement time.
    ill be going back to my Mitchelins. [img]/ubbthreads/images/graemlins/woohoo.gif[/img]
    Khufu's Avatar
    West coast of Scotland
    5,693
    [ QUOTE ]
    1.6mm for cars
    [/ QUOTE ]
    Yup, slightly scary for mopeds. It needs to be at least 1mm over a constant 75% but if it is less than 50cc you just need the tread to be visible over the complete tread!
    imported_fingermouse
    saw top gear a few years back testing tyres and they said 3mm for wide performance tyres. but that was just their advise.
