EM TuningJMB Retrofits
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Like Tree6Likes
Thread: Pipe Werx 3 " down pipe
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Any one on here recently installed or removed the pipe werx 3 " down pipe on the 8L S3?
    Scratching my head for the best way to remove it as it's rubing as the propshaft damper so need to make a strategic dent.
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Take it back to pipewerx and get them to do it as there exhausts are all custom made
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Pipewerx fitted mine, no dents required.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    It's not really pipe werx fault as it wasn't rubbing before.
    It's only after fitting an aftermarket mani that would appear to have moved the turbo slightly to the right thus pulling the downpipe over to the right as well.
    looks like a sub frame off job to remove....******** lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Was going to say Pipewerx are a quality brand, and never heard of a fitment issue..
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Have you tried moving the engine over slightly using the engine mounts?
    I did this to solve a similar issue with my downpipe. as with the engine as far over to the passenger side as possible mine does not rub at all now.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    If i moved the engine to the left or right it wouldn't change any thing as the downpipe and propshaft move together
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Ah ok yeah mine was very close to both the bulkhead and the prop so by moving the engine over it gave me a good 3 or 4mm clearance all round which stopped the knocking noise I had when turning left. I think mine was hitting the bulkhead though not the prop.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,275
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    My knocking from my DP (relentless 3") only stopped once I changed my engine mounts tbh.
    I did follow vrbob's advice above and it did solve the knocking slightly - but not fully- however once both of the engine mounts were replaced there hasn't been a knocking since from the DP.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Oh yes that's a good point I did also replace my engine mounts about the same time as Kwistof as my old ones were quite tired so this also changed how the downpipe sat. It was after changing these that I had to adjust the engine location to eliminate any unwanted noises.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Other than removing the DP and denting it where it rubes would be to make a 5mm gasket spacer for the DP to hotside to make the DP move over by 5mm.
    New engine mounts wont change any thing as well
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Yeah I see what your saying as if you made the gasket thicker the DP would move away from the prop towards the bulkhead leaving the engine etc in the same place.
    How much clearance do you have around the DP at the mo?
    Apr 2011
    Dublin, Ireland
    620
    I have also had this problem ever since fitting the downpipe. Was not too bad to begin with, but after fitting a relentless mani and new mounts, left hand turns under acceleration are nasty, with a horrible knocking sound and feel through the steering wheel. Hopefully when my new mani arrives and a shuffle of the mounts, it will be a bit better
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Well i dont wanna name n shame any one but its a high quality mani that ive fitted (not relentless) and its only since fitting that ive developed this problem.
    Currently there is no clearance and you can just turn the prop shaft by hand with the prop shaft damper rubbing on the DP
    RIP S3dave
    May 2004
    nr Glos
    7,167
    pictures
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Ill get some on tonight Bill
    badger5 likes this.
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Well here you can see the problem, quite clear they are rubbing but its enough to cause a PITT!
    And this is the rubbing from behind the propshaft damper.
    These 2 pics are with the supplied spacer fitted.
    Now this is with the oem gasket fitted instead of the supplied one between the Turbo and Mani.
    There is now a gap big enough to stop the rubbing.....BUT
    BUT now its rubbing on the feeking Flexi. If i could just move the props balance weight 2" back towards the end of the car id be happy with that but not sure the prop would shake itself to pieces.
    I think the only option left is to remove the Down pipe and dent it where it originally rubbed in the first place, which to say the least I'm not particular happy with seeing as i just put her back together again!
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Were abouts you based
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Quote Originally Posted by hoffmanvp3 View Post
    Std gasket std bore not suitable for oversize manifold bore. There is adjustment in downpipe to studs usually to rotate the assembly
    www.badger5.biz
    bill@badger5.co.uk
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Quote Originally Posted by s3joe View Post
    Aberdeen bud.
    Bill how may i ask you adjust the down pipe by rotating it?
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Too far than mate to take it to pipe werx
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Just a tad. Just feeked off i never spotted this while the head was off as it`ll be piss easy to have sorted then but that's life for ya lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its worth noting that the 3" pipewerx is what it says it is...3" where the relentless are not...
    hoffmanvp3 likes this.
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Aberdeen bud.
    clearanced holes in the DP flange so it can be rotated.
    we often have to pull them where we need them to clear prop and the flange hole clearance usually allows some margin or rotation.
    S3 Paul likes this.
    www.badger5.biz
    bill@badger5.co.uk
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    That`s one of the mods i`ll be getting my Machine shop to do on the DP Bill.
    Also pulling the head now as it appears i cant undo the 3 bolts on the DP as i used Nordlock washers on them as i didnt want them coming loose and now they will not budge so oh well i`ll be getting plenty practice with head gasket and timing belt lol
    There`s a few things i wanted to do while the heads off again, Wrap the DP with heat tape being one of them
    S3 Paul's Avatar
    Oct 2006
    2,764
    Mine is a pipe werx item and was a bugger to get right...
    I later found out it was for a TT?
    Although i thought they were the same ?
    Mine cleared the prop just the de cat section had to be cut and re welded as the bent in it made the centre section sit too low.
    All good now though. I did not fancy the job to be honest, I let a good mechanic i use do it.
    Noggy Blue 2001 S3
  28. #27
    Apr 2011
    Dublin, Ireland
    620
    Sounds like something I might need done. So what is it you do exactly. Do you drill out the existing holes on the flange(lengthening them) allowing the downpipe to rotated towards the engine.
  29. #28
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    U would need to elongate the 3 bolt holes but would need to be concentric to the main bore of the DP allowing a clocking motion to rotate clockwise/counter clockwise thus rasing and lowering the cat end of the DP to clear
  30. #29
    Apr 2011
    Dublin, Ireland
    620
    Thats what I was thinking.
  31. #30
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    Keep trying with the DP studs, you can't go removing the head just for that!
    I also Nordlocked mine on when i ran a k04, they took some effort to get off, but cracked off eventually with a bang and a bruised hand.
    Still preferable to pulling the head though!
  32. #31
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    I've got the ARP stud kit for the head so can re use so its just a new gasket so its not to bad and get good prices from TPS
  33. #32
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    this is an excellent idea.
    should prob be something for people to consider when first fitting one,just incase
  34. #33
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    I'm putting a patent on as I speak lol
    superkarl likes this.
  35. #34
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Quote Originally Posted by IrishDave View Post
    I have drilled oversize as well as filed them into slots as required.. It does'nt take much slot to move the DP a shed load..
    www.badger5.biz
    bill@badger5.co.uk
  36. #35
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Well predictably one of the 4 bolts holding the steering rack to the sub frame sheared on me last night so i`ll be sorting that first but did get the DP off last night without too much hassle, but those sub frame bolts sqreeshed on the way out which was a bit worrying until i could see they were removed in one piece
    So the left of the sheared bolt is being soaked on GT85 and will attack it again tonight lol
  37. #36
    RIP S3dave
    May 2004
    nr Glos
    7,167
    doh!
    unlucky dude
    www.badger5.biz
    bill@badger5.co.uk
  38. #37
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Its not a biggy but sorted it with a few improvements
    And the new version
  39. #38
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    Follow JoeeS3 On Twitter Visit JoeeS3's Instagram Channel
    I had exactly the same problem where my propshaft doughnut was rubbing against my downpipe. when I replaced my propshaft I only took the prop off to find a hole in the side of my down pipe from where it had been rubbing
    i'm not a genius...i'm a learner
  40. #39
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Did the DP knacker the damper shroud and start cutting into the rubber?
  41. #40
    JoeeS3's Avatar
    Apr 2013
    Cardiff
    355
    surprisingly no, the reason it was hitting the downpipe though was because I was missing a bolt in the damper so it was spinning correctly, its fine now though
  1. 3" xs down pipe and decat, or pipe werx?
    By s3clarke in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2012, 10:25
  2. Pipe werx down pipe and dog bone
    By krisrg87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2012, 18:18
  3. custom down pipe or pipe werx down pipe
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2010, 20:23
  4. Coupe V6 down pipe
    By grant_coupe in forum Classic Audi Forum
    Last Post: 18th September 2006, 20:05
  5. S3 3" Down Pipe
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2004, 04:44
