Badger5Volks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 51
Like Tree8Likes
Thread: 1.8t new internals.
    Feb 2014
    136
    1.8t new internals.
    hello people
    I have a 8l S3 with:
    Hybrid turbo (tfsi turbine and mfs compressor)
    3" downpipe and exhaust
    Badger5 exhaust manifold (requested iam waiting delivery)
    Bigger Injectors
    Big IC.
    Now i need some help because i have a AEB Head and 1.8t Block.
    i have doubts, i dont know what to fit in the block and the AEB head.
    I will fit 2.0tdi crankshat and 86.4mm pistons.
    Can someone tell me the best and lighter conrods and piston.
    About the head i want 8000rpm.
    what parts i need to achive this values
    Feb 2011
    Portugal
    162
    Bruto
    Talking about the 800hp by 0-400 S3 : "Is it true that everytime you take this car down the strip, the earths rotation slows by 0.1 % ??"
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Pistons will not fit
    Feb 2014
    136
    Quote Originally Posted by Broken Byzan View Post
    yes it fit, but we have to work bore
    Apr 2004
    12,523
    Not a chance. 83.5 is max on 1.8t block
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Quote Originally Posted by Miguel_S# View Post
    I think you are a little confused my friend...
    86.4mm is the stroke of the std 1.8 crank... TFSI stroker cranks are 92.8mm stroke
    1.8t blocks can be bored to a MAX of 83.5mm but no one really goes over 83mm as its not reliable and largely pointless...
    To convert your 1.8 20v to a 2ltr you will need a TFSI crank from a petrol engine (not a TDi like you posted unless this is a typo) and 83mm bore stroker pistons... JE or CP pistons are the normal ones to choose from and 9.25:1 to 9.5:1 compression ratio depending on manufaturer
    As for 8000rpm capable head... you may want to consider an 8000rpm capable turbo first... you will also need cams to get it breathing enough too
    Valvetrain wise you would need a full supertech setup so single groove inconel exhaust valves, single groove nitrided inlets and valve spring set..
    Std cams and a K04 hybrid will struggle take make power beyond 7k rpm...
    <tuffty/>
    Feb 2014
    136
    I want 8000rpm to improve top speed.
    i was hopping i only need valve guide to achive rpm....
    Feb 2014
    136
    very good info about pistons
    VWVortex.com - FAQ - 1.8t Pistons
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    887
    Add Vex182 on Facebook
    If you want to get to 175ish mph in 6th gear (7,000+ plus) you will need a turbo that can produce enough power to turn those gears fast enough.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Apr 2004
    12,523
    STROKE, not bore
    Feb 2014
    136
    Quote Originally Posted by Vex182 View Post
    I hope i can get 350hp at 8000 with This turbo
    RIP S3dave
    May 2004
    nr Glos
    7,185
    350bhp @ 8k?
    I dont think so.
    peak power will be at lower rpm
    Full uprated valvetrain for those revs.. and a nice balanced bottom end also
    TDi crank...?
    Hmmm
    Vex182 likes this.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Feb 2014
    136
    350bhp @ 8k?
    I dont think so.
    TDi crank...?
    Hmmm
    TDI crankshaft Part # 038 105 021 E or equivalent
    IE 06A 1.8T 20V 2.1L 2067CC Stroker Engine Kit (8.5:1 CR)
    i hope my engine will have those values more 500rpm
    RIP S3dave
    May 2004
    nr Glos
    7,185
    you will have more torque, sooner, but as for peak power being achieved that high I suspect not.
    it will have diesel torque with some more revs to play with I think
    www.badger5.biz
    bill@badger5.co.uk
    Feb 2014
    136
    So with a stroke i only win torque?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    The TDi crank messes with the rod angles too much as the 20v block is shorter than the 1.9tdi block... I have reason to believe that the TDi cranks don't make very high revving engines and your 8k limit may not be achievable
    <tuffty/>
    Feb 2014
    136
    <tuffty/>
    its 2.0 tdi, IE used in thid stroke kit
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    That part code is for the 1.9TDi crank... the 2ltr TDi is a larger bore is all... 1.9Tdi is 79.5mm bore by 95.5mm stroke... 2ltr TDi is 81mm bore by 95.5mm stroke
    As I said... the extra stroke of the TDi crank messes with the rod angles which means the engine won't rev as high as using stock stroke or the TFSI crank...
    Andrew@ALD has done this build though...
    <tuffty/>
    Feb 2014
    136
    <tuffty/>
    Thanks for sharing knowledge and experience.
    For my goals what do you recommend?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Stock crank, 83mm pistons. ALL the headwork, IE intake cam.
    if you insist on revving and having ANY chance of making power past 7.5k
    RIP S3dave
    May 2004
    nr Glos
    7,185
    revvy... is to pump more airflow thru a small engine on larger turbo (aka badgerwagen)
    you should spec total flow output from the turbo to your motor.
    Why the 8k rpm - ?? whats so special about the rpm? (top speed vmax run or something?)
    www.badger5.biz
    bill@badger5.co.uk
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    because racecar
    superkarl and Airs like this.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Feb 2014
    136
    I want the top speed is 300km/h
    How I spec total flow output from the turbo to motor?
    The compressor is a mfs tfsi 7+7
    RIP S3dave
    May 2004
    nr Glos
    7,185
    want top speed choose suitable gearing if this is your turbo choice.
    8krpm is spinning fast for 95.5mm stroker crank on 1.8t block
    www.badger5.biz
    bill@badger5.co.uk
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    186mph from a K04-023 hybrid....
    Is that even do able?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Feb 2014
    136
    Thanks for the information
    i will keep ori crankshaft
    But Badger you have car mapped with 345hp at 7600rpm with no large head, its so hard to have more 400rpm?
  28. #27
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    youre missing the point and misreading the dyno chart completely.
    where does it make peak power?
    it does not make any more power after 7k or so. At 8k it will nose dive faster than id muff dive on Amber Heard. Ie, pointless
  29. #28
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    To add, torque dies at 6k, power at 6.5k. It is out of its efficiency range
  30. #29
    Feb 2011
    Portugal
    162
    Using the IE intake camshaft can he gain something? Or it's the turbo beeing the limitation???
  31. #30
    RIP S3dave
    May 2004
    nr Glos
    7,185
    you need to read the dyno plot better miguel
    peak power not @ those revs my friend
    www.badger5.biz
    bill@badger5.co.uk
  32. #31
    Apr 2004
    12,523
    Quote Originally Posted by Pedrosousa View Post
    Nothing to gain from cam on this small frame turbo. Spend the money buying a bigger turbo instead
  33. #32
    Feb 2014
    136
    So the big problem in 8000rpm is turbo abilitie to flow the exhaust and exhaust temp????
  34. #33
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    no, the ability to flow significant airflow above those rpms (turbo shaft speed). If you had a compressor map and overlaid rpm for your displacement you would see that at X rpm the turbo would be out of its efficiency range and hence be making no more power.
  35. #34
    RIP S3dave
    May 2004
    nr Glos
    7,185
    want top speed fit a diesel gbox..
    had a lc180 in last week, diesel box, owner was'nt aware it was, 5th gear 3krpm was 95mph.
    long legged mofo.
    www.badger5.biz
    bill@badger5.co.uk
  36. #35
    Feb 2014
    136
    Thanks people.
    Now I understant, too keep power at high rpm it needs a big compressor wheel.
    Coating piston what do you think about this???
  37. #36
    Feb 2014
    136
    long legged mofo.
    Thanks but with this gearbox the car will be more slow and i dont want that
  38. #37
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I think you need a new car.
    superkarl and kwistof like this.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  39. #38
    Feb 2014
    136
    Quote Originally Posted by [Dave B] View Post
    Funny guy
    when i do something i like to know why and learn because learning is a great thing
  40. #39
    Feb 2014
    136
    I was searching and found ARROWS conrods, but they are very expensive.
    Titanium connecting rods - Arrow Precision
    30% WeigHt saving
    Titanium grade 6AL-4V
    CrN coated
    Did the weight saving makes difference our is a waste of money?
  41. #40
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    30% WeigHt saving
    CrN coated
    On a road car with a K04 yeah..
    <tuffty/>
    Vex182 and MexxT like this.
  1. Autotech Fuel Pump Internals 2.0TFSI - Brand New In Box!
    By S3 HODGE in forum For Sale/Wanted - Audi Cars
    Last Post: 21st June 2013, 08:05
  2. New venue for GTI International..
    By s3dave in forum Major UK Events
    Last Post: 4th December 2012, 14:51
  3. Brand New Autotech High Pressure Fuel Pump Internals
    By Paullie in forum For Sale/Wanted - Audi Parts
    Last Post: 12th March 2012, 19:50
  4. Seeing as it's New Year what's your calendar??
    By JohnH in forum General Chat
    Last Post: 10th January 2003, 17:10
  5. New Blunkpaunt Stereo's
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2003, 14:32
