EM TuningAH Fabrications
Results 1 to 7 of 7
    Oct 2005
    Chester
    50
    Lowering Springs
    Hi
    thinking of lowering my car (just replacing the springs) and I was looking around at the choices of springs available. Its a 1997 1.6.
    I know the majority of you guys will advise on Eibach but what do you make of the ones available on Eba like these ?
    Was also looking at the Koni's?
    Any views at all?
    Daveo
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: Lowering Springs
    That isn't cheap in my opinion, have a look at www.motorsportworld.co.uk for some other choices - they seem to be very cheap for the stuff I've been looking around at.
    Oct 2005
    uk
    317
    I'm going for H&R springs used em before on my vw's
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    would this have any effect on the audi warranty?
    Jun 2004
    Crowthorne, England
    2,512
    I'll be going for the Bilstein / H&R combination, but it seems you need to have the adjustable tie rods for the rear if you're actually going for a handling improvement so I'll be waiting until I can afford to get the whole lot done at once along with the ARBs.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    If you want to retain some ride quality i would deffinately go for Eibach or H&R, I had Eibach on my A4 and ive got H&R on my S3 both are excellent. My experience of cheaper alternatives is that they dont do development work, they just take the standard spring settings and increase the stiffness by 20% or so and reduce the length of the spring. This generally results in poor ride quality.
    Timbo's Avatar
    Slowest car ever round the Top Gear track?!?
    Dec 2004
    Surrey
    275
    [ QUOTE ]
    ... it seems you need to have the adjustable tie rods for the rear if you're actually going for a handling improvement...
    [/ QUOTE ]
    Needless to say only on the Quattros... FWD have much simpler trailing arm/torsion beam setup and hence no tie rods to adjust (as the original post was about a 1.6 I would presume it's FWD).
    I bought my springs & dampers from motorsportworld and I found them to be helpful and friendly as well as cheap!
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
