Sky InsuranceBadger5
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By jojo
Thread: adjustable rear tie bars
    2nd gear sorts em out
    Jan 2013
    preston lancashire
    150
    right i bought som adjustable rear tie bars because i lowered mr car with apex springs a while ago went to a garage to get them put on today but the four wheel alignment the had wouldn't fit on my car as its to low can't get the things on the tyres , but he said that maybe the tracking could be out on the back , he said that the tyres had worn quite evenly but I've been threw to sets on the back now to the ones i put on the front since its been lowered are these adjustable tie arms going to do any good ? any help please !
    Marshall878's Avatar
    Jan 2014
    March, Cambs
    134
    Sounds like the rear is toeing in causing excessive wear.
    From my understanding, you need to install the adjustable arms in place of the LOWER existing arms. This way you pull the bottom of the tyre in, rather than pushing the top out, achieving standard camber and toe.
    Factory toe just doesnt seem achievable when installing in place of the upper arms and pushing the top of the tyre out.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Quote Originally Posted by jay22s3 View Post
    Go somewhere else for your wheel alignment mate, too low!? Lol. I'm running Apex springs, no issues getting mine done! The sensor things clamp onto the lip of the alloys where I go, so unless the alloy itself is sitting under the wheel arch, it can be done.
    Airs likes this.
    Jan 2013
    preston lancashire
    150
    the ones this garage had sat on top of the wheels with metal arms thats why it couldn't be done there
    Jan 2013
    preston lancashire
    150
    is marshall 878 right about the adjustable tie arms going in place of the lower arms and not the top ones ? thanks
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I believe you will find it easier to get the required geo you require by replacing them with the lower arms
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Toe and camber can be sorted with a combo of tie bars and adjusting the trailing arms by undoing the bolts securing them to the body and moving them... tie bars on the bottom will pull/push on the trailing arms affecting toe depending on what you are doing
    Fitting adjustable tie bars is normally for getting rid of the excessive negative camber you get from lowering springs... fitted to the bottom you will need to pull them in to remove neg camber and this in turn makes the rear toe out so moving the arms inboard at the point they are bolted to the chassis brings toe back in...
    <tuffty/>
    Mar 2013
    Devon
    622
    With my adjustable tie arms fitted to the top, and set up as well as the trailing arm adjustment would allow on a Hunter machine my toe was still miles out of spec. Knackered a rear pair of Pirelli P Zero in 1500 miles.
    Got it aligned a few weeks back with the adjustable tie bars moved to the bottom, lined up perfectly:
    Jan 2013
    preston lancashire
    150
    thanks guys just had the car on the hunter 4 wheel alignment system at a garage in liverpool today and it was miles out it feels miles better now almost like a new car ! just waiting for some polly bushes to come and then get the adjustable arms fitted , it was a bit pricey £65 plus vat to straighten it up but after getting in it was well worth it he said to take it back when i get the arms fitted and he'd just charge me £30 to set the rear up properly , things you have to do when you start messing around with cars wish i had kept it standard now its costing more than a women, but more fun this way as it dosent moan like a woman
    Jan 2014
    March, Cambs
    134
    I bought mine with the rear springs on. Toying with the idea of buying the arms but the cost was putting me off and was considering putting the standard springs back on.
    Luckily some arms came up cheap....just need to fit them and get the 4wheel alignment done.
  1. Should I get adjustable rear tie bars when lowering?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2011, 16:19
  2. New Look Forge Adjustable Rear Tie Bars
    By DPM in forum DPM Performance
    Last Post: 22nd October 2009, 10:35
  3. KW Adjustable Rear Tie Bars Back In Stock!
    Last Post: 17th June 2008, 10:07
  4. Alternative to adjustable rear tie bars???
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2007, 22:22
  5. Adjustable rear tie bar installation
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2007, 17:50
