    Mar 2014
    Southampton
    new here needs help with headlights
    Hi im new here and I have recently brought a audi a3 1.9 tdi 2000 model and I never really liked the separate indercatoir and headlight so I got some face lift headlights out the scrap yard the all in ones they did not fit stright in to place I had to remove a bit of metal from each wing the prob I have now is that it seems like the high beam and main beam are the wrong way round high beam seem to be on all the time and main beam only comes on when you use the flasher could any one shead some light on to why this is happening and what I can do to sort the problem thanks ash
    Stevofoz's Avatar
    Aug 2013
    Hockley, Essex
    Follow Stevofoz On Twitter
    Always best to check the stickies for this sort of info.
    headlight upgrade, is this the right choice...?
    2001 S3 Dolphin Grey - Totally Standard...for now....
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Headlight wiring adapters are needed if you don't fancy cutting the wiring, I got a set of eBay for about £35
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Mar 2014
    Southampton
    Thanks for reply I have discovered that the high beam is comeing on when just turning the lights on normal witch I could not understand because I took the wireing loom out of my old lights and fitted them in the new face lift lights if I just cut the wires and swap them over will this work
  1. New member needing a bit of help with headlights
    By coreythorny in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2013, 18:12
  2. Newbie with A3 and need help with headlights
    By m19hna in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2012, 14:36
  3. New on here.. need help with engine ECU
    By scottyaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 13:22
  4. New Diff Fitted Today!!!! Need Help with 4 codes...
    By coopsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2010, 21:16
  5. New here and need help with codes.
    By 98Quattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2008, 23:43
