Badger5AH Fabrications
    Bristol
    37
    High level brake light
    Hi guys,
    Have tried the search on here but to no avail...
    Stupid question = how do I change one of the bulbs in the high level brake light at the top of the boot? Have had a pole around but can't seem to get at it?
    Thanks in advance
    Mar 2013
    Devon
    614
    Pull the plastic trim away from the top of the boot lid, need to be firm with it. You can then see the light unit, it is only held in with a single screw at one end, the other end slots out.
    Assuming you have the older style one with bulbs instead of LEDs, then it is easy to replace the bulds when its removed from the car.
    The bulbs you need are T1.1/2 wedge, 12v, 2.1w. They look like a mini side light wedge bulb.
    Bristol
    37
    Thanks very much, all sorted!
  1. High level brake light bulb change
    By TimG in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2010, 07:11
  2. Replies: 0
    Last Post: 9th September 2010, 12:34
  3. LED High Level Brake Lights
    By mike_plymouth in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2010, 16:07
  4. high level brake light
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2009, 18:47
  5. Changing high level brake light bulb
    By mac_xpert in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2007, 15:21
