Volks AutosSky Insurance
Results 1 to 12 of 12
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    Add stock211 on Facebook
    audi a3 temperature gauge problem
    hi i recently fitted a new engine coolant temperature sensor as my gauge wasn't working. cleared the fault code with vcds lite and all was well for a week, now the gauge has stopped working again,did another scan and vcds is reading the temperature fine and isn't throwing any codes so dont think the sensor is bad.have any of you guy and gals got any idea's as what could be wrong? cheers in advance
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    thermostat?... please define 'not working'
    <tuffty/>
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    worked fine for a week sitting at 90, all of a sudden needle not moving at all. but on scan temperature rising as normal ???
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Which temperature are you logging? the CTS has two sensors... one for the ECU and one for the dash... you will need to go to the instruments module to log the sensor for the dash...
    Is the CTS an OE one? have seen GSF and ECP pattern parts fail fairly quickly in the past..
    <tuffty/>
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    the sensor i replaced is the blue four pin one, i thought 2 wires were for the ecu and the other 2 were for the gauge ?? the temperature reading on vcds were on 17 instrument >measuring blocks >group 3 i think. is this right or i'm i looking in the wrong place..bit of a newbie where vcds is concerned
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Blue 4 pin? is yours an AGU?
    Sounds like the right group in VCDS... if its rising to 90 and the dash needle isn't moving then sounds like the dash is faulty... not sure if something like will throw a fault code... have you check the fault codes in the instruments module?
    <tuffty/>
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    engine a AGN,thats what confusing me no fault codes in instruments..think i'll have to try another sensor.think it was a pattern part even tho it cost 15 quid...
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    what i need to know is there a way to test the 4 pins on the sensor?with a multi meter? and if so how would i go about this
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    If the ECU is seeing temps and the instruments are seeing temps then the issue is the clocks mate
    <tuffty/>
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    thanks for the advice,would the clocks just die after fitting a new sensor,could it be a fuse or a short in the wiring just want to be sure before buying new dials:thumbsup
    stock211's Avatar
    Mar 2014
    macclesfield
    19
    just a quick update...with the help from youtube and a multimeter How to test a Coolant Temperature Sensor - YouTube i was able to test the ECT sensor, and found out it was bad. lesson learned fit oem parts not cheap ones from ebay. as the cheap one only lasted a week, we now have a working temperature gauge sat at 90.....very nice
    May 2012
    RETFORD, NOTTS
    1,753
    Another way is to check output displays in instruments with vcds. not always conclusive but does diagnose a faulty needle motor
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Temperature Gauge Problems / Fan Codes / Cluster and not the normal fix!
    By TimCrighton in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2012, 10:01
  2. Fan, Temperature gauge and Coolant problem
    By D89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2012, 13:07
  3. audi a5 fuel gauge problem
    By mbdj in forum A5/S5/RS5 Forum
    Last Post: 28th February 2011, 14:16
  4. temperature gauge a4 tdi problem
    By neal in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 16:01
  5. Temperature gauge not working, bit of a problem
    By cookie_a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2008, 12:27
