Results 1 to 14 of 14
    Jan 2014
    46
    Smile AH Fabs V2 Intercooler, Help
    I bought an Audi S3 and its got an AH Fabs V2 Intercooler. From what I've read these intercoolers should allow you to retain the fogs & grills. However its a different story with my intercooler.
    The previous owner has chopped through the grey bumper surround for the pipes to fit?
    Below are pictures of the intercooler with the bumper off? I have bought a new set bumper grills and the grey surround, I dont really want to butcher them.
    Can someone advise, what seems to be the problem?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Not sat it low enough... have you got the brackets attached to the bottom of the crash bar? if not do that and then you may have to pack it down with a few washers
    I went to great lengths designing this to fit and retain fogs etc... looks as though it wasn't fitted properly to me...
    <tuffty/>
    Jan 2014
    46
    It has got brackets. If you look at the first pic, intercooler is not sat right. When i took the bumper off, i have manged to make it sit bang on center and now the both pipes look right.
    So i need to pack it with washers and bring the whole intercooler a tad down?
    Jan 2014
    46
    I'll get some more close up pics to show where it touches the bumper?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Quote Originally Posted by GOLF-MK3-GTI View Post
    Yes... pack the brackets down so the bottom of the FMIC sits on the bottom part of the bumper... the pipe work will then be in the right place... I packed mine down by using 3 x 2mm thick washers each side IIRC...
    <tuffty/>
    Jan 2014
    46
    Jan 2014
    46
    Tuffty; Judging from the above pics, Do you think there's movement to bring intercooler down?
    Also does anyone have any close up pics running the same intercooler, Just to show how its sat?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Of course... its how I designed it ;P
    Like I said, pack between the bracket and the bottom of the crash bar... this will position the FMIC lower and sit the pipes in the correct position
    <tuffty/>
    Apr 2011
    Dublin, Ireland
    611
    I have the same intercooler and it fits fine. Funny thing is though I only used 1 washer. Yes it is still a bit of an effort t get the bumper back on, but it does fit.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    Jan 2014
    46
    Cheers guys, Job for the weekend then. Will report back on how i get on.
    Jan 2014
    46
    All sorted now thanks.
    Freeman_1986's Avatar
    May 2013
    Forest Of Dean
    112
    I'm sorry, but whoever did that clearly doesn't give a ****... Looks terrible.
    S3 AMK (AKA FUTURE CLASSIC )
    Mods So Far: PCV Delete, N249 Bypass, S2K Filter, Black Side Indicators, FMIC, B5 TIP, Rear Anti Roll Bar, Polybush Upgrade.
    Mods Wanted/Planned: Wheel Spacers, Moar Silicone, 3" Downpipe, Decat, Debadge Rear Rings, Spray Front Rings, 8P/V Gear Knob, REVO!!!!!!!
    MISC: Sort Out Paintwork...
    Because It Makes No Attempt To Be Great, It Is Therefore Extremely Great.
    Jan 2014
    46
    Exactly, New bumper grill and insert have been fitted also intercooler has been pulled a tad lower. It looks so much better with the fogs in now.
  1. uprated intercooler help
    By jonny1985 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2013, 14:13
  2. Front mount Intercooler help !?!
    By Lee23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2013, 11:00
  3. A3 8L 1.8T quattro Intercooler help
    By Morty in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2012, 11:52
  4. intercooler help needed?
    By jack.s in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2009, 01:07
  5. Please help me here people... intercoolers,
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 10:05
