AH FabricationsChris Nott
Results 1 to 9 of 9
    Oct 2012
    238
    Knocking noise from rear on uneven ground??
    On my s3, not had an arb link go before so don't know if the sound is right, but I have a knocking noise coming from the n/s/r corner, can push the car down at that corner and it'll knock slightly, don't really hear it so much on smooth roads, but driving down the lanes it's pretty annoying!! Especially as the rear seats are out so it's even noisier.
    So is it most likely to be an arb link? It's not the exhaust or heatshield before anyone says as I've checked that.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Could also be rear top mounts
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Oct 2012
    238
    I didn't think they had top mounts as such? Not like the front anyway? Just rubber discs that go at the top and bottom of the spring... Or do you mean the shock mounts?
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    425
    What's it on... A3 or S3/Quattro?
    Oct 2012
    238
    S3
    epox's Avatar
    Oct 2012
    Glasgow
    569
    Broken tail on the spring, is the top bolt for the shock loose?
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,086
    Not sure if the S3 has the same stone guard as the A3 on the rear trailing arm, but mine was broken and only made a noise over uneven ground.
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    Jun 2011
    Great Melton Norfolk
    1,348
    Spring broken
    Oct 2012
    238
    Its not a broken spring, ill check the shock bolts tomorrow, good idea !
  1. Knocking noise from rear on sportback TDI quattro
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd January 2008, 22:21
  2. strange noise from rear of car @ 4500rpm +
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2007, 17:50
  3. Knocking noise from my Coupe Drivetrain!
    By strokes in forum Handling
    Last Post: 6th October 2005, 16:33
  4. knocking noise from front after lowering car
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2005, 18:16
  5. Clonking noise from rear of the car
    By JasonM in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 19:51
