[ QUOTE ]
Standard set-up works well with the rest of the toys I've got, you'd be surprised.
[/ QUOTE ]
I've been there...and I can assure you, you can improve front end grip, turn in and balance by not having standard settings!
Standard settings are awful...and they sell the chassis short.
I had mine long enough to know what works and what doesn't...I pretty much changed everything...and ended up with one of the sweetest handling Ss around - as anyone who's driven it / owned it will confirm.
[ QUOTE ]
I need bigger brakes before I really play with the settings. No point in going faster if I can't go slower.
[/ QUOTE ]
Again, I disagree...
I ran standard-ish brakes for years...and sorted the chassis out before / during...and you can still cover ground quickly with standard-ish brakes...the standard brakes are fine for road use if maintained. Not as good as Brembos...but perfectly fine.
