Results 1 to 29 of 29
Like Tree4Likes
  • 1 Post By <tuffty/>
  • 1 Post By cooper86
Thread: PCV repair
    Midlands
    314
    PCV repair
    Hi
    I'm going for the repair approach rather than catch tank.
    Found the split part, 06A 103 213 AK, and almost fell off my seat when I found out its £50!!!
    Wasnt paying that, so I brought 0.5m of pipe from a boat chandler. Only issue is that the internal bore is quite a bit smaller than the broken part, is that important ?
    It's a 210 bhp AMK engine, and the pipes aren't the same as on the guide, why is this ?
    Also snapped the dip stick, with part of it getting stuck inside the tube from block!
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    May 2013
    Birmingham
    212
    Is this the part? http://bit.ly/TfvAYb a bit cheaper on eBay but not sure on quality. I had the broken dipstick when that pipe snapped on mine had to pull the bits out with a screw driver!
    Midlands
    314
    Hi
    I've replied to this once, not sure what's happened.
    It's not the part in picture, that part is the other side of t piece and goes into block.
    Dave
    Midlands
    314
    But thanks for replying
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    <tuffty/>
    Midlands
    314
    The part isn't on the picture, think it would be the blue arrow.
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Ahhhhh... I know the part...
    Yeah, bonkers expensive for a plastic pipe... the one pictured below...
    I replaced mine with a metal one from an Ibiza as there was one available when I looked through the parts bin...
    Normally use 19mm ID hose for doing PCV deletes etc... may be worth looking into doing that and fitting a catch can... works out a little more than 50 quid but at least its spent doing something worthwhile and getting rid of all the stuff under the inlet that rots and splits causing more issues down the line
    That assembly of hoses in the pic above (excluding the bend from the ebay link) is around 100 quid on its own
    <tuffty/>
    david7m likes this.
    Midlands
    314
    That's the one
    My repair for now it's diesel marine fuel line, internal bore was about 6mm, is that ok ?
    Dave
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Yeah I bent over for one those - about £40ish I think I paid. What a rip off!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Quote Originally Posted by david7m View Post
    That's the one
    Dave
    Too small tbh... 19mm else the pcv will back up from lack of breathing capability and blow oil out of seals and anywhere else it can
    <tuffty/>
    Midlands
    314
    <tuffty/>
    I'll get something bigger
    Will I lose the brakes if it pops off? I guess not as its been split for some time.....
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Dave
    No... brake servo is on the opposite end to the throttle body...
    <tuffty/>
    Midlands
    314
    But all part of the delete if I go that route ?
    Wish I'd left it now, as now worrying I've damaged some of the servo related hoses.
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    The servo hose is attached to the 'V' shaped hose on the end of the inlet manifold (washer bottle side)... for the delete you just connect whats left of the hose of the servo to the outlet on the end once you have removed all the pipes etc from underneath the inlet
    <tuffty/>
    david7m likes this.
    Midlands
    314
    Thanks Tuffy
    Dave
    Apr 2013
    Barry S Wales
    60
    I think i might have the pipe that tuffty has posted, i think the one i removed was metal tho? I removed it all to fit catch can. I'll have a look up the garage in the next couple of days to see if its still there or been thrown out if you want?
    david7m likes this.
    Midlands
    314
    That would be great, but I'll let you know if I need it if I can't get it working today.
    Dave
    Apr 2013
    Barry S Wales
    60
    Dave
    Yea thats fine mate. I cant get up the garage till tomorrow maybe thursday to have a look.
    May 2013
    Birmingham
    212
    Just checked I have one of those maybe 12 months old from when I fitted my catch can your welcome to hadn't got round to chucking all the scrap pipes out yet.
    Oct 2013
    34
    I replaced that exact hose this week! I used one of these , four of these and two of these. Quite abit larger than the pipe thats in it originally, but it seems to of done the job. You have to go under the existing pipe thats in the way rather that over it though due to it being less flexable, So closer to the gear box linkage.
    Midlands
    314
    Quote Originally Posted by Wallm0nkey View Post
    Is it the plastic version ?
    Dave
    May 2013
    Birmingham
    212
    Yeah plastic about 2 weeks after I had the car last May the elbow by the oil filter split totally so ended up replacing that in the process noticed that one was split. If it's any good to you I'll post it to you it's currently in the back of my van connected to everything else as I'd been meaning to chuck it all away!
    May 2013
    Birmingham
    212
    Just got a picture of it
    Midlands
    314
    Looks good. Is it split ?
    Dave
    May 2013
    Birmingham
    212
    No appears totally sound it was brand new when fitted and has done less then 10k miles only taken off for the catch can to be fitted. I don't want anything for it as it was destined for the bin but if it's of help to someone it's a bonus.
    Midlands
    314
    Cheers wallmonkey, sent a pm last night.
    Dave
  28. #27
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Good work guys... ASN community spirit working at its best
    <tuffty/>
    JD09 likes this.
  29. #28
    Midlands
    314
    Got the pipes today, fantastic!
    Wallm0nkey you're a true gent
    Thanks again,
    Dave
  30. #29
    Dec 2009
    Herts
    54
    Is this pipe also known as a charcoal something or other?
  1. A3-180HP; 25HP lost in engine change after repair
    By manueltrigo in forum General Technical / How To
    Last Post: 4th February 2004, 11:42
  2. Repairs
    By lsoexped in forum TT/TT-S/TT-RS Forum
    Last Post: 12th November 2003, 13:51
  3. Stone Chip Repair
    By djmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2003, 13:59
  4. Repairing RS TT wheels
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 15:51
  5. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
