Monster MotorsportBadger5
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    wandering fuel indicator
    Hi guys, i have an issue at the moment where my fuel guageboth the needle and the trip will fluctuate dramatically. It does settle itself eventually but is started to get on my wick..
    Any ideas on a fix?
    Cheers,
    Matt
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Mines done this a few times too when I've been sat warming the car up. I just ignore it but wouldn't mind knowing what causes it!
    S3 - APY silver
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Have you scanned for fault codes? I have heard of this being caused by a dodgy speed sensor in the gear box
    The dash uses the speedo signal and a couple of other sensors to stabilise the fuel gauge when going up and down hills etc
    <tuffty/>
    If in doubt, flat out!
    Dec 2013
    Alnwick, Northumberland
    37
    check fuse for reverse lights and if not that, then check wiring to both the speed sensor and reverse switch and also earths. If not it may be a speed sensor.
    Mine was just wiring
    Audi S3 Imola Yellow APY
    N249 Delete, 80MM TIP. About to carry out major engine surgery :S
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Checked for codes, nothin popped up. Reverse lights and fuse are sweet. Brake switch was changed awhile back. Where one the gearbox would one find the speed sensor to check it over?
    May 2012
    RETFORD, NOTTS
    1,753
    If the fuel guage and the trip are going up and down i would have said maybe the sender unit in the tank? Ive only ever seen the needles playing around.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Fuel gauge indicator with a mind of its own
    By tquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2012, 08:24
  2. VAGCOM code inside. No warning buzz (fuel / door / light / indicator noise)
    By insanekiwi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2011, 12:43
  3. Fuel Indicates half even filled it up
    By lwen in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2004, 19:48
  4. Fuel Regulator
    By Joshie in forum General Technical / How To
    Last Post: 8th January 2003, 13:12
  5. Clear Indicator Bulbs
    By Moresauce in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2003, 01:17
