Sky InsuranceAH Fabrications
Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By daz-20vt
  • 1 Post By J44KWED
Thread: S2000 air filter fitted - these noises normal?
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Fitted my s2000 air filter to my s3 just now and with the bonnet up still the fluttering sound as you dump the throttle is really a lot louder, does it mean my Dv is gone or is it normal to expect increases dv fluttering noise with this filter?
    the car boosts well as usual by the way nothing else would suggest any issues.
    S3 - APY silver
    Feb 2012
    1,102
    I didnt think a dv fluttering was a good thing? It will get louder with an open filter though.
    Are you using an oem dv
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Yeah standard everything except the filter, maybe it's just me. There was no noises before, should I replace the dv incase? From what I gather they aren't too expensive anyway.
    S3 - APY silver
    Feb 2012
    1,102
    Well like i say the dv noise will increase. I think a fluttering oem dv means that its split inside. Search fluttering dv fella.
    Prawn likes this.
    Aug 2011
    Plymouth
    744
    Add Lavis89 on Facebook
    Could possibly be a split diaphragm on your dv, for the price of a new one it is worth picking one up, if it doesn't solve the problem then keep it as a spare
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Here's a video clip of the sound. It only does this when dropping the throttle either stationary or going along. When going through the gears it doesn't do it - just a pshhh sound.
    Does it sound like my dv is gone or is that normal? It has always made this sound under the conditions explained above only now I've changed to a s2000 filter it's much louder and more noticeable. I have also recently done the n249 delete with 4mm ID silicon pipe as per the How To sticky on here. All pipes secure but could a kink in one cause this? Will check tomorrow.
    S3 - APY silver
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    62
    Thumbs up
    I think there's definitely something wrong there, it shouldn't be chattering! This is what mine sounds like with a Badger5 v3 TIP & JR Filter, and its a Forge 007p Valve, N248 Removed, Also have the bonnet sound deadening removed.
    http://www.toon-ring.co.uk/s3.mp4
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Will, Mine made that flutter sound as soon as i fitted the s2000 filter. I changed the dump valve last weekend (£30 from trade parts specialist) and it now makes a nice clean whoosh noise. The dv was definitely fried before. I'd suggest you change it. Easiest job in the world to swap.
    J
    Lavis89 likes this.
    Aug 2011
    Plymouth
    744
    there is your answer then
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    either needs a new DV, or the vac line to the DV is kinked.
    It will almost certainly have been like that before, but the stock airbox stops you from hearing the obvious sound.
    As a bonus, with a fresh DV, you should get a bit more power and better fuel economy I know I did when I first changed a broken DV about 7 years ago!
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Thanks for the help guys, much appreciated! I'll check the lines first but I'll try and get a new dv today for the sake of £30. Need to buy a cam cover gasket set anyway so will phone audi.
    You wouldn't happen to have the part number for the dv, anyone?
    Thanks again!!
    S3 - APY silver
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Been quoted £53.72 by audi for a new dv. He said he had two on the system. Does the dv have a multiplug on the side of it? Or is that the n75 he's quoted me for? Because I thought the dv was a simple inlet outlet to 90 degrees of one another - no multi plug or electronics on it ...?
    S3 - APY silver
    Marshall878's Avatar
    Jan 2014
    March, Cambs
    134
    £50 is about what i paid for the N75 on mine.....id certainly question that. There's no plug on a DV to my knowledge!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,558
    Part number 06A 145 710M
    <tuffty/>
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,272
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by willh92 View Post
    You are correct- there are no electrics on the OEM DV for out car and it is practically an inlet and outlet 90 degress from one another.
    Do you not have a TPS that will sell to you?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    all sorted! got the dv as pictured by tuffty above coming. He had ordered me the N75 instead!
    Cheers!
    S3 - APY silver
  1. Benjamins S2000 air filter mod.
    By BENJAMIN in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2014, 15:52
  2. S2000 air filter mod - problems / questions
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2013, 22:15
  3. S2000 Air Filter
    By Pubemammal in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2013, 20:10
  4. A3 1.8t Air filter fitting?
    By Steven.c in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2011, 14:34
  5. Pipercross air filter fitted
    By JeffY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2009, 18:24
