Volks AutosEM Tuning
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By epox
Thread: -5.99° Steering Angle Sensor (G85) how to reset?
    epox's Avatar
    Oct 2012
    Glasgow
    584
    hi tracking done but -5.99° showing on Steering Angle Sensor (G85) reading, how can i set this to 0 any ideas
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    '02 A3 TDI quattro sport
    8L IS DE BEST
    epox's Avatar
    Oct 2012
    Glasgow
    584
    great thanks
    mark
    epox's Avatar
    Oct 2012
    Glasgow
    584
    not working for me error pop up when putting in 40168.
    cheers
    A3 TQS
    Jul 2013
    Devon
    163
    Seems this guy had the same problem with the login, although he doesn't say if it fixed it, he didn't come back to say it didn't either.
    The Audi TT Forum :: View topic - Vagcom help
    epox's Avatar
    Oct 2012
    Glasgow
    584
    all sorted, it was me just being a twat. was changing the softcoding rather than using the 40168 to login!!!!!
    s3dave and rupe like this.
    epox's Avatar
    Oct 2012
    Glasgow
    584
    Sensor for Steering Angle (G85)
    Prerequisites:
    Start the vehicle.
    Turn the steering wheel one turn to the right and one turn to the left.
    Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    Ensure that the steering wheel is not moved again.
    Keep the engine running and do not switch off the ignition.
    System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Coding-II - 11] GOTO LOGIN NOT CODING AND ENTER 40168
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 2 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was succesful, check the sensor again.
    [Measuring Blocks - 08]
    Group 004
    [Go!]
    Check field 1, the value has to be between -4.5 and +4.5 °.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    THIS MIGHT HELP SOMEONE
    cheers
    Mark
  1. Steering wheel angle sensor g85 part number and price ?
    By Gillm in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 8th January 2014, 19:53
  2. Steering Angle sensor (G85) mechanical malfunction.
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2013, 10:27
  3. g85 steering angle sensor prob
    By defsix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2010, 21:00
  4. Vag-com, steer angle sensor, 2000 S3
    By MONKIEE in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2006, 20:01
  5. Steer Angle sensor, location
    Last Post: 14th May 2006, 18:06
