JMB RetrofitsAH Fabrications
Like Tree1Likes
  • 1 Post By Alex C
Thread: Can I Fit a 2001 Audi S3 Gearbox In My Standard 1.8t Quattro 2000 A3?
    Feb 2014
    Hi, I'm new to this so I apologise if I don't make sense.
    I currently own a 2000 audi a3 1.8t Quattro and the gearbox is getting to the end of its life. I was wondering if it is possible to fit a S3 gearbox in its place? obviously a gearbox of the same year or close to. and if so is there any extra things I will need to purchase?
    hope you lads can help. thanks
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    You want to ask that question in this section: A3/S3 Forum (8L Chassis)
    not the site support section
    Sandra likes this.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,458
    Yes you can use an S3 gear box (or a TT one for that matter)...
    Is yours the 5 speed box or the 6 speed box?
    Main differences between these boxes other than a few gear ratios is the cable connection points and transfer box bracket design... early boxes use a ball and socket for gear cable connections where later boxes use a pin and clip type setup... earlier boxes use an alloy bracket for the transfer box support to the back of the block, later boxes uses a steel one... 2001 is a change over year so early AMK S3's have the ball/socket and alloy bracket setup while later AMK's (and BAM's) have the pin/clip and steel bracket setup...
    If yours is ball/socket and new box is pin/clip you can swap the parts from yours (changer arms) and you are good to go... your 2000 A3 should have the alloy type transfer box bracket, if the new box has the later steel one then make sure you get the bracket with the box and just use that... the alloy bracket doesn't fit the later box from what I can see (although I have not gone out of my way to try) but the later bracket setup will fit your car so no real drama
    <tuffty/>
  1. "Awesome" retro fit cruise 2001 Audi TDI 130
    By robgosty in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2010, 23:15
  2. Can you fit the new audi a3 wing mirror with indicators onto a 53 plate?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2009, 18:42
  3. What Audi HU can I fit to a 2001 8L?
    By alijames in forum In-Car Entertainment
    Last Post: 7th March 2008, 14:04
