Hi everyone,
Newbie here... new on the forum and new to Audi. I just picked myself up a lowered Audi A3 1.9 TDI 130BHP (2002) and I love it already.
Drives well and I've fixed a few bits and pieces of cosmetic stuff and fitted a new radio.
Only 1 thing bothers me - the traction light comes on after driving with a bit of speed and stays on until the ignition is switched off and back on again. The ABS light does not come on (I've noticed the two can sometimes come together from other threads I've read). I also get some wheel spin if I take off too fast, and it can get a little wobbly on corners (is this maybe just a result of the lowering).I bought a VAGCOM kit online and did a quick scan, the results are below.
Engine
17911 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
17978 - Engine Start Blocked by Immobilizer (I think I know why this has come up!)
18057 - Powertrain Data Bus: Missing Message from ABS Controller
A/T
Couldn't get codes from this - it gave a linking error.
SRS
No codes
ABS
01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
Do you reckon I've much to worry about? Any ideas from the codes and the traction light?
There's one other thing too. I'm not sure when the cambelt was last changed - how much does this usually cost? I read that VCDS can indicate the cambelt condition by running some tests - is this the case? I'd be interested to know how to do that (I bought a VAGCOM USB cable too and downloaded VCDS lite).
I haven't done any car repairs before - but knowing what might be wrong will help me find the right person to sort it, or maybe I can start to learn how to do it myself....
Oh - and the fuel gauge gets stuck at halfway too!
Apart from all that though - it's a dream machine
Cheers!
Engine
A/T
SRS
No codes
ABS
Cheers!
