Chris NottVolks Autos
Results 1 to 13 of 13
    Jan 2014
    47
    Audi S3 Brakes Help - Porsche 996 4POT
    Hi
    My S3 has Porsche calipers on the front from a 996? I need new brake pads as the brake pad warning light keeps glowing then going off.
    My question is which brake pads do i need? I can get a pic up id that helps?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    what you need is a part number mate. If you look on the front face of the caliper you'll find a part number starting in 996.
    If you get that part number we can help you
    Jan 2014
    47
    Hi I've had a look, part number is 996.351.425.
    Also would you know discs have been used?
    Thanks for the reply
    Jan 2014
    47
    Anyone??
    Adam P's Avatar
    May 2012
    Southampton
    396
    Brake upgrades is a current area im looking into however i have had some great advice and help from another forum member who knows his stuff when it comes to brakes and that's tom, his user name is 'future' might be worth asking him directly via pm.
    2001 Audi S3 8L Ming Blue - Rebuild Complete
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Just seen the reply, sorry for the delayed response mate.
    Your other caliper will end in part number 426
    They are from the front of a 996, either a carrera 2, carrera 4, or a boxster S. I would imagine on your car they will be running on a 330 x 28mm disc.
    You can ask for pads for any of those cars at your local motor factors, or search online for performance pads.
    Jan 2014
    47
    Thanks for the replies guys. What car is the 330 x 28mm disc from? would you know?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    the 330 x 28mm disc will be from an alfa brera, but the PCD is incorrect and has to be re-drilled to suit the 5 x 100 hubs on your car.
    It's possible to buy the discs direct from Hi-Spec and have them re-drill the PCD for £50 before sending them out.
    Alternatively, you could get a set of 2 piece discs from the likes of badger5 if you wanted to spend a bit more
    Jan 2014
    47
    Hi Prawn,
    Cheers for the info. How do i get in contact with Badger5, to get a quote for the discs?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    S3 Paul's Avatar
    Oct 2006
    2,764
    I had a set of those calipers and was planing to run them on the 312 stock discs... never got the idea off the ground though... it was a few years back now ,
    Noggy Blue 2001 S3
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Run best on a 28mm Disc Paul. there are now carriers available directly off ebay to fit these with the brera 330 discs. Actually a pretty simple straight forward swap now
    No huge advantage to these over LCR brembos really, but they do look nice
    S3 Paul's Avatar
    Oct 2006
    2,764
    I made a cock up when buying parts... wanted to run them with LCR discs... Bill broke the news to me it wasnt doable... swept area on the disc was too small for the pad face...
    It was for my 'charged VR6 that was on 17's so space was an issue and i lost heart and sold them to buy a GT jnr kit.
    Noggy Blue 2001 S3
  1. GTech Big Brake Kit - Audi S3 TT Porsche 996 Boxster calipers
    By firestorm in forum For Sale/Wanted - Audi Cars
    Last Post: 24th November 2013, 22:33
  2. Porsche 996 Boxster S Front Calipers 996351426 996.351.425 big red Audi S3
    Last Post: 24th November 2013, 22:22
  3. Fitting Porsche 996 front brakes- a small write up
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2012, 13:14
  4. 2000 Audi S3, High OEM spec, Porsche wheels, 4Pots, Weitecs etc
    By Scruffydubber in forum For Sale/Wanted - Audi Cars
    Last Post: 30th November 2011, 22:09
  5. porsche 996 brake setup,, advice please!!
    By S3BN_H in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2011, 17:15
