Badger5Chris Nott
Results 1 to 7 of 7
Thread: Blanking Stuff
    Nov 2013
    Nottingham Derby
    110
    Blanking Stuff
    Did the SAI, N249 & PCV to Catch Can bypass & just left the Sensors plugged in. Everything fine & no Dash Light. Also removed the Charcoal Canister, blanked off the nipple on top of the Inlet Manni & the one on the other side of the Canister. Left this Sensor plugged in aswel but after I give the car a little foot to floor action I get the dash light. Torque App says it's a purge fault on the Canister, clear the code & it's okay for a while, little playing & it's back on again. So am I supposed to block off any of the nipples on the Charcoal Canister Sensor?
    Nov 2013
    Nottingham Derby
    110
    Anyone? I thought this would of been a easy one for you modded guy's
    Nov 2013
    Nottingham Derby
    110
    120 views with not 1 Post lolol. Can someone even say if you can wipe out the Code when I eventually get a Map?!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,900
    Quote Originally Posted by CarbonBlack View Post
    Can wipe the code but if its a fault it'll keep on popping up,ask and offer beer tokens for help off here
    VCDS USERS MAP
    Nov 2013
    Nottingham Derby
    110
    I can clear the Code with my Torque App but I thought that with some things you can wipe them out for good in VCDS?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Some things can be written out of the ecu from a competent mapper, not sure VCDS can do much delete if any...
    Nov 2013
    Nottingham Derby
    110
    Cheers mate, yeah I meant writing it out of the ECU when I get a Map. You think the Carbon Canister can be written out?
  1. Squeks and Green stuff on the sunroof???
    By necroeire in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2004, 13:34
  2. Wireless network thingy stuff ... any advice?
    By wigginer in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 16th January 2004, 09:59
  3. key blanks
    By cbass in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2004, 16:01
  4. Blanking number plates in pics
    By AlexStanley in forum General Chat
    Last Post: 4th November 2003, 12:28
  5. Williams F1 Team Stuff
    By ianmack in forum Detailing
    Last Post: 19th July 2003, 00:07
