EM TuningChris Nott
Results 1 to 17 of 17
Thread: Coil packs
    Jan 2014
    south wales
    86
    Coil packs
    Ok have faulty coil packs but just wondering which ones do I get I have an aum engine but an aeb head which takes bolt down coils id like to get these as mine are just pushed in ATM but will the connections be the same?
    Feb 2006
    Lincolnshire
    691
    All the connectors are the same as far as I know for these era cars. Certainly my brother and I swap coils and his is a Leon.
    Audi S3 - 2002MY - Denim Blue
    Jan 2014
    south wales
    86
    Ok cheers mate
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    351
    All OEM push down coil packs are on recall so you might be able to get the swapped out for free... Worth bearing in mind
    Jan 2014
    south wales
    86
    Where 2 dealers how do I know if they are oem?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Quote Originally Posted by Audi_A31.8T View Post
    AEB head code makes no difference... cam cover dictates (to a degree) the type of coil pack used... in actual fact if you ordered coil packs for an AEB they won't even work on your car...
    Not knowing your setup I would suggest using push in packs (OE ones from a dealer or TPS) and make sure you have the push down type cam cover fitted
    If I understand what you are saying though you have the AEB head and its got the bolt down type cam cover? if this is the case you can either source a proper cam cover and use the coils designed for the car or you will have to order coils for an APY S3 as these are compatible with your wiring and are bolt down type
    If you give a dealer your reg number you will end up with push downs
    <tuffty/>
    Jan 2014
    south wales
    86
    Will push downs for my reg be ok?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    You have a facelift AUM A3? thats had an AEB head fitted?
    Push downs will be fine
    <tuffty/>
    Jan 2014
    south wales
    86
    Cheers bud yea been a nightmare but determined to get it wright lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    What coil packs do you have now?.... and what cam cover was fitted?
    <tuffty/>
    Jan 2014
    south wales
    86
    This 1 lol
    Crazypete00's Avatar
    Oct 2007
    225
    arent the coilpacks covered by a recall?
    Jan 2014
    south wales
    86
    Yes but I have no idea if these are oem and where do I go to get them?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    They aren't OE ones from what I can see... the intermotor sticker is a give away...
    You can check the others by pulling off the plugs and looking at the lettering on the coil packs connector... it should haev a part number and the word 'VAG' on it somewhere if they are OE
    OE coils you can get from a dealer (Audi, VW, SEAT or Skoda as they are all the same) or TPS...
    <tuffty/>
    Jul 2011
    351
    Phone your audi dealer and ask about the coil pack recall... They'll book it in and have a look to see if any of them are eligible
    And if you're REALLY (and I mean REEEAAALY) lucky they'll give your car a clean as well
    Jan 2014
    south wales
    86
    lol cheers will check in the morning may just buy new from tps
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    I doubt they will change non OE ones...
    New they are 30 ish each IIRC
    <tuffty/>
  1. Coil Packs
    By mattr in forum Other Brands & Models
    Last Post: 4th February 2003, 19:10
  2. MOVED: Coil Packs
    By mattr in forum General Chat
    Last Post: 4th February 2003, 18:42
  3. Who needs Coil Packs?
    By NeuSkoolA3 in forum General Chat
    Last Post: 25th January 2003, 13:50
  4. Coil Packs - what do they do ?
    By audi_girl in forum General Technical / How To
    Last Post: 11th January 2003, 13:12
  5. Coil Packs - has anyone got one!
    By audi_girl in forum General Chat
    Last Post: 10th January 2003, 21:11
