JMB RetrofitsSky Insurance
    If in doubt, flat out!
    Dec 2013
    Alnwick, Northumberland
    37
    Oil Breather System Pvc
    As you can see, I have a slight problem.
    How can I bypass this for now until I can get new parts?
    Cheers Ben
    Audi S3 Imola Yellow APY
    N249 Delete, 80MM TIP. About to carry out major engine surgery :S
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Thats the main block breather... there is no 'bypass' for this as its a required part of the PCV, you will need to find a way to connect this up realistically...
    Even the PCV bypass still requires a hose to be connected to the plastic elbow in some form
    <tuffty/>
  1. How to change oil breather?
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2009, 13:14
  2. Where to get an Oil Breather Pipe other than Audi?
    Last Post: 13th October 2009, 23:48
  3. Oil breather pipes (replacing)
    By CO11K9 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th December 2008, 22:02
  4. Oil Breather Pipe
    By Audi-Max in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2008, 11:22
  5. S3 BAM - ESP/Oil Breather Pipes
    By jesters3 in forum Parts Requests
    Last Post: 18th July 2008, 17:26
