Hand brake adjustment
david7m
Midlands
Hi
Am I right in saying there isn't any ?
I've fitted new pads but the hand brake still requires 6 clicks. Is this normal, just looks a little high?
Guess new cables would be the next option which won't be happening.
Dave
Try checking underneath the ashtray in the centre console behind the handbrake. That's where it was on mine.
Both calipers work well and I will check near the hand brake itself.
Just out of interest, how would a seized caliper affect the travel?
Cheers,
Dave
Rear calipers are self adjusting aren't they? Try yanking it up and down a few times, and it should require less click to operate the handbrake. I stand to be corrected though....
Make sure when you fit the callipers back on that there isn't a big gap between the pad & disc. Wind out the piston slightly to make it sit closer to the disc then adjust the 10mm nut under centre console.
Reactions: david7m
Yeah, going to revisit the calipers at the weekend to check they evenly wound back in as in my picture above it doesn't look like it's pulling square....
Dave
