Volks AutosJMB Retrofits
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Logging Session - Review and Input???
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Good Morning,
    Myself and ShaunS3 did some logging sessions on Sunday on both of our S3's.
    Can anyone have a look through mine and see if there is any area's of concern or if she is ok?
    Sorry to sound a noob, but this is the first time mine has had some logs done, and I'm quite new to this.
    Anyway my spec:
    - 2000 APY (Mileage 136,150)
    - Milltek CAT Back
    - Milltek 200 Supercell Sports CAT
    - Badger5 V2.2, JR Filter with heatsheild
    - Forge 008p Valve
    - N249 Delete
    - N112 Bypass
    - Superchip SRP Stage 1 Map
    No fault codes recorded before or after apart from incorrect flow detective on the N112 Valve
    Here's the logs:
    Run 1 - Log (Groups 001/002/115)
    Run 2 - Log (Groups 001/031/118)
    Run 3 - Log (Groups 003/020/118)
    There was a little traffic on the private road we used to do the logs so Shaun has taken out the parts where we anchored on and geared down etc. Hopefully the log should still be significant to point out any problems....
    Any help whould be much appreciated.
    Thank You.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    The only thing I can comment on is 193grams seems very low. Mine is mapped with a V1 TIP and sees 223grams... Even if the exhaust makes little difference to the breathing, I'd say that's low.
    mark_S3's Avatar
    Sep 2012
    Wakefield
    600
    Quote Originally Posted by JD09 View Post
    Yeah it seems abit low considering the modifications.
    I was expecting abit more tbh.
    Hoping someone can shed some light on the logs and see if there is any issues I should sort out.
    [IMG][/IMG]
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,266
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Give the cone filter a good clean by soaking it in solution
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    mark_S3's Avatar
    Sep 2012
    Wakefield
    600
    Quote Originally Posted by kwistof View Post
    The JR filter is practically brand new....
    [IMG][/IMG]
    JD09's Avatar
    Dec 2009
    3,080
    That might be the issue. Mine appeared to knacker my MAF, switched back to OEM airbox and it's been fine. I'd try testing the MAF either by DIY cleaning it or switching it out for a new one.
    Nov 2013
    108
    194 G/S is like 240bhp, superchips advertise 270hp from a flash so you would expect ~220 G/S if that were true.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Can't gauge power on these logs... never hit peaks revs on full load so will always be under its full potential... you can also discount logs where the coolant temp is not up to temp as its in warm up/cold start up to this point...
    For reference logs should be done when the coolant temp is around 90 degrees and in at least third gear from 2000 rpm to redline (or as close to it as is legal/safe) foot to the floor... this will put the engine under full load and give meaningful results
    JD, the 193gs is only at 5.8k... that 1k below OE redline... if allowed to rev out (dunno what the superchips redline would be lifted to if they do it at all) then it should pick up some airflow but looking at it you may still only be looking at 200gs or there abouts...
    <tuffty/>
    kwistof likes this.
    JD09's Avatar
    Dec 2009
    3,080
    <tuffty/>
    I noted that, Paul, but saw 6,6 entry in the logs as well, but with a very low figure and presumed this was just turbo tail off at the top end.
    My logs looked similar when my MAF was faulty, but I'd take Tuffty's advice and redo the logs, 3rd gear, 2k- end of revs.
    mark_S3's Avatar
    Sep 2012
    Wakefield
    600
    <tuffty/>
    Thank you tuffty for the above...
    I'm a newbie to logging, so I'll have a word with Shaun about re-doing the logs. And hopefully squeeze a few more ponnies out of her.
    Dont suspose looking at the logs there is anything to be worried about?
    She runs great and deserved all the maintenance she's had recently.
    Although the previous day before logging she had a few flatspots above 4500rpm which was cured by re-gapping my NGK BK7RE plugs to 0.7mm. They where only fitted 2 weeks ago, and must of gapped them wrong as 3 plugs where 0.1mm out and other 0.2mm out. Always double check your mesurements ;-)
    [IMG][/IMG]
  1. Northwest VCDS logging session 13/4/12 - 7pm
    By Sandip in forum Smaller (Local) Events
    Last Post: 14th April 2012, 01:22
  2. NW logging session and mini meet last night (31/08)
    By Dibdub1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2011, 08:23
  3. AITP 2011 REVIEW AND REFLECTION
    By DriveByShooters in forum Major UK Events
    Last Post: 15th August 2011, 19:48
  4. Full Reviews: All Popular iPod Tools Review and Download
    By lalilala4334 in forum Video Gaming
    Last Post: 6th February 2010, 19:41
