EM TuningSky Insurance
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By kwistof
Thread: Clutch slipping
    Nov 2010
    25
    Clutch slipping
    Hi guys,
    After a bit of advice, basically my clutch is slipping at 3/4k when in 3rd or 4th and flooring it, the car has a stage one remap from revo, i put in new standard clutch about 9months ago and looks like its not upto the job, i thought it would be, what are you opinions?, also what are my options?? i think i was told i could have a stage 1 revo map which delivers the power later on in the rev range, do revo offer this?
    if changing the map is a waste of time then what are my options regarding clutches (which ones are worth going for) the cars (s3) only had a stage 1 revo map, i'm not going to increase the cars power anymore, i would like to keep the standard clutch feel, i may track it once a year
    your advice is appreciated
    Thanks,
    Hardeep.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Stage 1 should be fine on a standard clutch especially a new one!
    Mine was stage 1.5 for 18months on the original clutch 115k miles and a few launches and when I replaced it (my gearbox died) it still looks like its got some life left in it and wasn't slipping at all.
    I did upgrade mine as the gearbox was being replaced so seemed silly not to.
    Personally if I had put a new standard one in 9 months ago and its slipping already I would be contacting the clutch manufacturer/place it was fitted as I would guess its still covered by warranty but obv still gonna have labour costs involved swapping it out
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    Hi Hardeep
    If you had the clutch replaced 9 months ago, there should be no reason its slipping on a stage 1 map, it should be fine with that, unless you are launching it at every opportunity??
    Where are you based?
    The map should be fine, but if you were to get it changed, it maybe worth getting in touch with the likes of Bill at Badger 5 (Gloucester) or one of the lads at R-Tech (Hinckley).
    What was the reason for getting the clutch changed previously too, was it because it was slipping as well?
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by Nilz View Post
    I was going to say the OP could travel 10k miles a month or he could have a season pass to RWYB up Santa Pod - or even both! lol.
    What make was this clutch as well Hardeep?
    LUK or Sachs you want to stick to really buddy if you want to stay standard/OEM and keep with the same quality of parts.
    Nilz likes this.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    May 2012
    RETFORD, NOTTS
    1,753
    check out my lightened helix clutch and flywheel for sale. Granted the peddle is heavier but you get used to it, and it doesnt slip ever!!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Nov 2010
    25
    hi guys,
    thanks for the replies...
    vrbob - i think i will be contacting eurocarparts soon then as i totally agree standard clutch should have been more then fine with just a stage 1 remap, it was a LUK 3pc clutch kit (which i was told by many places is the original audi one part no 637441710, part no of just the clutch is 324 0302 10) with a brand new dual mass flywheel (LUK)... what clutch did you go for and how much? what power can it take?
    Nilz - no i dont launch it at every given opportunity mate its my daily drive so i have to take care of it, obviously i give it some every now and again but not a silly amount where after approx 9months after fitting a new clutch should see it slipping. i did speak to revo yesterday about what i was reffering to in my first post about having different settings for how aggressive the power delivery of the stage 1 is, the revo guy said theres either standard of linear and that theres different settings ranging from 1 - 10 depending on what i might have asked for regarding aggressiveness pretty sure mine was set to 7 but he agreed stage 1 on a standard new clutch shouldnt be an issue, so not sure i will go down this route i.e changing the setting of the map...... in terms of the companys you've named i'm confident in the garage i used as its been fine (the clutch)for 9months no juddering etc unless your referring to them giving me advice on clutch options? oh and i'm near heathrow pal, oh the reason i changed the clutch originally was because it was slipping car had done almost approx 48k and one track day which consisted of around 2hrs of track time only did about 10/15 laps of brands hatch, then i had it remapped which didn't seem abnormal, my cars now done just over 52k
    kwistof - it was a LUK 3pc clutch kit (which i was told by many places is the original audi one part no 637441710, part no of just the clutch is 324 0302 10) with a brand new dual mass flywheel (LUK) since the new clutch i've only used it going to work and socially, work is only 4.5miles away
    so what are my options guys?
    looks like i'll have to replace the damn clutch again but replace it with what? like i said i would like it to drive like standard so no paddle clutches and nothing that will slip after 9months also from where?
    thanks for the response so far guys keep them coming need to sort this out ASAP, all knowledge appreciated.
    Thanks,
    Hardeep.
    Marshall878's Avatar
    Jan 2014
    March, Cambs
    134
    Ive just bought a car with a slipping clutch. 24,000 miles covered in 18months, REVO map.
    Not impressed
    Dec 2011
    Somerset
    506
    Quote Originally Posted by Marshall878 View Post
    Not impressed
    Looks like the REVO map has too much torque and or has a nasty torque spike
    Get the right reduced torque file re map and it will see a slightly slipping clutch with the torque spike stock map, disappear.
    Yes, a cure for clutch slip, a reduced torque, super smooth map.
    Jan 2014
    March, Cambs
    134
    Thats the plan! Dont really want to be buying a new clutch just yet!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    OE clutch will handle normal stg1/2 torque but as said the initial onslaught of torque can tax things... Revo is quite aggressive, alternative mapping methods in custom maps can tailor torque delivery to suit personal preferences and rods (or the lack of them)...
    Banging the boost in too quickly also has the detrimental affect of generating too much heat too soon... this makes the hardware hot enough that consistency between runs on the dyno drops... Bill has been using different techniques to mitigate against this and the result is repeatable power figures without turning the turbo into a heat pump...
    Clutch choice and clutch wear is hugely subjective....
    <tuffty/>
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    I'm on the original clutch at 111,500 miles and it's been mapped since 90k without any slip at all. I think it's some down go driving and some down to the mapping for sure. I am careful on my clutch, as in I never hold it on it and slip it as little as possible.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Clutch Slip
    By simonwjones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th September 2006, 16:41
  2. Clutch slip! & another problem
    By IanMcA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2005, 23:33
  3. is my clutch slipping?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2004, 19:29
  4. chipped A3 tdiq clutch slipping....anyone else??
    By A3Lee in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 23:38
  5. clutch (slipping?)
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2003, 12:29
