Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Dec 2013
    Driver door noise annoying
    On my s3 when closing the door its make a proper messed rattly noise like something is loose inside. Window goes up and down without a problem. Just had my subwoofer fitted and can hear the door rattling alot more what can it be ? Any ideas before i open up.
    Jan 2014
    24
    You should see a problem as soon as it's taken apart... Could surely be a list of things like a screw falling out, plastic broken etc...
    May 2013
    Birmingham
    211
    Have a look at your crash bars in the door passenger side mine was loose causing an annoying rattle when using the door takes about 5 mins to check!
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,256
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I had this issue - turns out the window regulator and other fixings were replaced at some point and seems like the previous owner forgot to take some of the broken parts out from the bottom of the door frame so they were rattling about. I expect the parts that were loose were always there- the sub you've installed has just made it more distinctive..
    10-15 minute job to whip the door card off - give it all a check and then replace. May as well check both door cards as well.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    My side impact protection bar was also loose on the drivers side which squeaked and rattled a little. For some reason the nuts would not tighten up so in the end I managed to get a nut and bolt in there instead done up bloody tight
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Dec 2013
    What does this protection bar look like never delt with sumeh like this
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    its a big metal bar inside the door to stop them caving in during an accident.
    you can see the bolts as they are visable with the door card on so first thing to try would be just go over all the fixings you can see and make sure they are tight.
    Next step is pop off the door card and then knock on bits till you can narrow down whats rattling
    Dec 2013
    Thats great will get round to that. My woofer dosent help the rattle
  1. Drivers Door Creaking Noise. (Aaaarrrgh!)
    By Jenno in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 14th January 2014, 20:04
  2. Loose Drivers door handle cover
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st June 2005, 21:05
  3. button on drivers door inner seal...
    By Welch in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2005, 18:06
  4. Drivers Door Problems
    By deano16v in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th February 2005, 19:31
  5. A6 Rear Driver Door Problems
    By daver in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st December 2004, 21:13
