Badger5EM Tuning
Results 1 to 9 of 9
    Oct 2012
    birmingham
    246
    whining noise from rear
    ive got this whining noise from the rear whist driving is it my diff its only just started today also ive put 20mm spacers on rear not long ago
    Jul 2011
    wiltshire
    137
    could be brakes, could be wheel bearing whine, could be diff, anymore info? does it get worse with speed, is it there when you brake? spacers being fitted shouldnt cause problems unless a componant in the suspension line is faulty/failed, the spacers could in theory cause extra strain on the rest of the drive train,
    Oct 2012
    birmingham
    246
    there at about 30 to 50 mph
    Jul 2011
    wiltshire
    137
    rear diffs can benifit from fresh oil, my advice would be to empty and refill diff, and see if that solves the noise (cheaper opyion) then if it still persists id be inclined to think along the lines of wheel bearing, normally diff whine is horrendous, you could jack the car up on axle stands all around and rock the back wheels and check for slop/slack,
    Dooshbag
    Feb 2012
    Exeter
    15
    Sounds like the spacers could be something to do with it, possible wheel balance. Can you feel any vibrations through the seat? Would recommend checking your wheel nut torque immediately just I case the wheel has slightly loosened! Then follow rusty's advice
    Oct 2012
    birmingham
    246
    right replaced the diff oil yesterday and the whining noise is still there it gets louder at speed
    Feb 2014
    111
    i had this problem and was convinced it was the diff. I threw on a different set of wheels with better tyres and the noise disappeared. I couldnt believe it.
    Oct 2012
    birmingham
    246
    ive had these tyres on for about 6 months now with no probs i think i will take the spacers off tommorow and see if that works its really ...sing me off now
    Oct 2012
    birmingham
    246
    spacers of same thing im gona burn the fu.ker
  1. High pitched noise from rear speakers
    By Jay4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2007, 14:50
  2. strange noise from rear of car @ 4500rpm +
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2007, 17:50
  3. Noise from rear wheel - Tyre problem ? Help
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th February 2007, 19:22
  4. Noise from Rear of A4 saloon
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2006, 09:25
  5. Clonking noise from rear of the car
    By JasonM in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 19:51
