Badger5Volks Autos
Thread: Maf sensor ?!?
    Jan 2014
    south wales
    92
    Maf sensor ?!?
    Ok so still having running problems and didn't even think to check maf
    so the maf looks like brand new but when I unplug it when the car is running there is no change most other cars the revs will drop or show signs that it's been unplugged! I'm thinking it maybe the wiring to the maf is there anyway of checking if you have power to the maf?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    If there was a wiring issue like that then it would throw a fault code... most running issues are down to air leaks...
    What model/year is your car? I am assuming its going to be a 2001 later A3 (AUM engine code) based on what you have said about pulling the MAF as wideband engines run ok with it unplugged unlike AGU's
    If you have access to a registered version of VCDS check block 032 to see what fuel trims are doing..
    <tuffty/>
    Jan 2014
    south wales
    92
    Car starts and runs great at idle but as soon as you pull away and put your foot down it just won't rev up and can here poping noises from the engine somewhere. It's gotta be something simple just can't find it!
  1. possible maf sensor fault........ pls help
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2006, 09:24
  2. Help please - 1996 A4 1.8T MAF sensor cleaning ?
    By philwest in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2004, 23:59
  3. Prices of MAF Sensors
    By BadBoy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2003, 17:28
  4. MAF Sensor/Induction kit
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2003, 09:10
  5. maf sensor
    By tvr1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 09:52
