Badger5Sky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Like Tree2Likes
Thread: Treated my injectors.
    Jan 2014
    33
    After recently buying my S3 I am now started to sort things out with regards getting a good basis to improve the power to Stage 2.
    Started things off today by giving the injectors a once over so here is the process :
    Initial ultra sonic cleaning to remove all the "gunk"
    Into the next ultra sonic cleaner after all the initial dirt has been removed
    All hooked up to the tester to visually observe the spray pattern which was pretty good
    Next was a leak test which I forgot to photograph but no leaks were found up to 7bar.
    The injectors were then fired for 15 seconds to observe if they all emitted an equal and correct amount of fuel
    For some reason the next few photos failed to capture properly but the results showed that 2 injectors were down and 2 were good. this process was repeated a further 2 times to ensure it was correct. Again the same 2 were confirmed down. Filter baskets were then removed and placed into a Third ultrasonic cleaner and electrical connectors which cycled the injectors to ensure all fluid was passed through the injector body and nozzle. This process was repeated several times with the injectors being retested until an acceptable result was achieved with all injectors producing the same volume of fuel.
    The new filter baskets and seals were then installed
    Finally, all done and ready to be re installed
    Now I know the injectors will not be causing any problems soon
    Nilz likes this.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Is this something you do for a living? if not who did you use and how much was the service if you don't mind me asking as looks like a great idea
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    Very good!
    Jan 2014
    33
    Quote Originally Posted by vrbob View Post
    I'm a mechanic by trade in a small garage and a colleague of mine does this as a home business! He's still in the stage of building up stock to sell aswell as refurbing them but I've sent some mates his way already for it. Just finished helping a mate with an Ibiza cupra R doing a K04 conversion and he had 2 poor injectors which would have affected him greatly.
    The treatment mine had today I believe is £40 plus £6.95 for postage if that's how you choose to do it if you're not local
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    mrinjectoruk did mine. Same service. Very good price
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Thanks for the info,
    Just need a couple of days when not using the car then so I can send them away to be serviced.
    Jan 2014
    33
    What did they charge out of interest?
    Jan 2014
    33
    No problem, as far as I know the day he receives them he Does all the work so at his end the turn around is nearly immediate!
    Midlands
    314
    Looks good!
    How does the £40 compare against buying new ones ?
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    Jan 2014
    33
    Quote Originally Posted by david7m View Post
    Looks good!
    Dave
    2 second search on ebay was £50 new buy it now on one unit, so very good in comparison
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    I can't remember exactly, but in the same sort of region your mate charges. 40odd plus postage which is special delivery.
    Feb 2012
    1,085
    You guys notice any improvements in doing this? I thought it would cost a small fortune!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by daz-20vt View Post
    I dunno I did it to sell my stock injectors as mint.
    people have been diy cleaning them for a while and report good things in smoothness and mpg. Several members have bought ultrasonic cleaners to do there's, they aren't expensive
    Feb 2012
    1,085
    Yeh just seen they start at 20 quid lol. Can that really do the same job? Gotta be worth buying even for a one off
    Jan 2014
    33
    A good ultrasonics cleaner dependant upon needs is £350 but the real kit is the tester to measure spray pattern and flow under different pressures etc. each injector will have a rated flow and it's all calculated properly until it reaches it's desired flow rate.
    Mine felt very smooth afterwards to drive, but I'm the case of my mate who had 2 injectors rated at "poor" he would have certainly noticed a huge difference.
    dentsy's Avatar
    I HAVE THE OPTION CODES
    May 2007
    BLACKWOOD, SOUTH WALES
    238
    Wow what a fab idea ! Is the price the same for 2.0 tdi 140 injectors ?
    How close are you to South Wales ?
    Si
    Jan 2014
    33
    Quote Originally Posted by dentsy View Post
    Si
    Petrol injectors only I'm afraid mate!
    dentsy's Avatar
    May 2007
    238
    Dogs gonads 😒😒 can diesels be done ?
    Jan 2014
    33
    Diesel injectors are much more complicated mate and I would imagine the process to be much more complicated if it is possible atall
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Perhaps point your mate in the direction of this thread as it may generate him some business.
    Jan 2014
    33
    Ill let him know, would you think this service would be popular amongst the forum?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by Gunner3011 View Post
    He would need to apply to be a forum trader, otherwise it would soon get closed down.
    Jan 2014
    33
    How would that work then does he email admin or something? Also what's the score with stuff like that as in if I want to a garage and they gave me a good service and I recommended them would the thread be deleted as they don't trade for the forum?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Recommendations are fine, forum trading isnt.
    You need permission from admin yes.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Best bet would be to contact the admin team to confirm but people often recommend business and services on here. eg like Superkarl did with MrinjectorUK above
    So if he has a website you could link to it as that makes no odds at all as far as I am aware (obviously with a forum discount lol)
    Jan 2014
    33
    Gotcha, I've passed it onto him and he's going to look into it after work tonight with the Admin side of it etc!
    I recommend him as a great service though with fantastic value and impressive results
  28. #27
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Nice always good to have good people with actual real world reccomendations
    I have found the service mrinjectoruk offer on ebay and looks like it works out at £45 for 4 injectors including postage
    Fuel Injector Ultrasonic cleaning Testing | eBay
    So if your mate can offer the same if not better service for the same or less he should do well
  29. #28
    Feb 2012
    1,085
    How hard or easy is it to remove and reinstall the injectors? And do you need new seals after? If so where might i find them? Thanks !! Daz
  30. #29
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,266
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Not sure if the pics still work in this....they aren't displaying on the PC I'm currently on
    http://www.audi-sport.net/vb/a3-s3-f...pic-heavy.html
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  31. #30
    Jan 2014
    33
    The full price works out at £46.60 from mr injector as the postage listed is for one item but he applies discount for multiple items so he does however work out 35p cheaper.
  32. #31
    Jan 2014
    33
    Very easy mate, undo 2 5mm Allen key bolts and remove each injector by pulling out the retaining clip and job done
  33. #32
    May 2013
    Birmingham
    212
    I'd be interested in getting mine done just need to sort out when we can be minus the car.
  34. #33
    Jan 2014
    33
    Quote Originally Posted by Wallm0nkey View Post
    Turn around is very quick so there wouldn't be a weeks wait or that. The day they are received they are serviced and reassembled and dispatched the following morning via Royal Mail special delivery
    JD09 likes this.
  35. #34
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    So if I've got this right, £45 ish for all four injectors cleaned and checked (no car issues, so presume mine are OK) by a pro, or £45 on a DIY kit (granted this could be used on friends and future cars)?
    Sweet, thanks Karl et al.
  36. #35
    Jan 2014
    33
    £45 on a DIY kit? Lol there's a reason a proper set up costs thousands. The link posted above showing the DIY thing at home only cleans the outside of the injector?
    The injector wasn't pulsed to clean the internals, seats and Pintle but merely cleaned the outer body. The spray pattern wasn't observed nor was the flow rate so it is impossible to confirm if the injector is flowing correctly and producing the same as the other injectors and has no idea if the spray pattern is correct.
    Buying an ultrasonic bath will make your outer body clean and that's about it I'm afraid.
  37. #36
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,266
    I only put that link up there because Daz required a fitting/installation guide and that's pretty helpful (if pics are displayed).
    2000 S3 APY
  38. #37
    JD09's Avatar
    Dec 2009
    3,080
    You clearly know a lot about this subject, so not to doubt you, but surely if petrol can get in the top and out the bottom, cleaning fluid and water can also get in. And therefore, when in an ultrasonic bath, clean the insides as well? I appreciate it will not check the flow patterns. I am purely going off the thread linked in the stickies/above!
  39. #38
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    JD, lots of members have bought US cleaners for their injectors, hell I did it about 3 years ago. Everyone inc myself reported smoother idle, running and mpg.
    However
    As gunner says, its nothing on the service his mate and mrinjector UK offers. For £45 use a pro service.
    for an old car with old injectors I think its worthwhile doing it once.
    Thanks to gunner for providing people with an In depth review
  40. #39
    Jan 2014
    33
    Quote Originally Posted by JD09 View Post
    Petrol is forced through the injector though and not simply left to find its own way through. also if your injector was blocked it would require pressure from the electronic pulsing to clear it or even back washing to remove it. The cleaning is only a minor portion of the objective too, testing the injectors for leaks, spray pattern and equal/sufficient flow is arguably the most important stage. After all, what use is a clean injector that starts leaking under 3 bar of pressure?
    In reference to petrol can get in and out of the injector, true! ... But only if electronically controlled. Hence the electronic pulsing off injectors whilst in the ultra sonic tank. Without the electronic signal to operate the solenoid inside the injector, the pintle will remain closed therefore allowing no fluid to pass. If fluid is passing then your injector is leaking but you may not be able to tell this as the injector would be submerged which is where all the testing equipment comes in highlighting such a problem.
    Hope this clears up any queries on this subject
  41. #40
    Jan 2014
    33
    Here's a picture that failed to upload yesterday showing the injectors being pulsed in the solution to fully clean the internals.
  1. uprated sparks and injectors?
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2004, 08:58
  2. Injectors
    By Ryanc in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2004, 18:38
  3. S3 injector flow rate/max HP
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2003, 11:43
  4. Injectors
    By AL_B in forum Diesel forum
    Last Post: 27th August 2003, 16:26
  5. I need the part # for 310cc injector..please
    By austurbo in forum Tuning
    Last Post: 1st August 2003, 11:04
