Results 1 to 15 of 15
    epox's Avatar
    Oct 2012
    Glasgow
    600
    any links to front wishbone replacement?
    as title.
    thanks
    mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Anyone?
    Ta
    Oct 2011
    760
    Took mine off to do the bushes, its not that hard.
    Take wheel off.
    Undo xenon level sensor.
    Undo track rod end ball joint.
    undo bottom ball joint, and seperate and then the other two bolts the hold the wishbone to the sub frame and pull out.
    Putting new bushes in is the hard part, you need a press or take to a garage.
    Good luck
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Whishbones came with polys fitted so replacing them and ball joints tomorrow.
    Oct 2011
    760
    Takes a bout an hour each side.
    If your handy with the spanners it should be less.
    Hardest part was lining up the bolts to sub frame when putting back on.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    887
    Add Vex182 on Facebook
    I've changed wishbones on's few cars but not on the S3 and they are usually nota issue to do. Just remember the headlight adjuster on the passenger side (If I remember correctly). Also get the front wheel alignment done after as it is likey to be out due to the new bushes and the adjustable lower ball joints.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Thanks for the help, going to get camber and tracking checked as car is crap in the wet.
    Mar 2013
    Devon
    616
    Quote Originally Posted by jezzy View Post
    Take wheel off.
    Good luck
    Yup, but no need to undo track rod end.
    It helps to soak the wishbone bolts with penitraiting fluid or WD40 before you start. The rear one is not too bad, but the last thing you want to do is snap the front bolt or pull the treads in the subframe. If it goes tight work it with plenty of light oil.
    Nov 2011
    Leeds, UK
    287
    You'll need to get a spanner onto the top nut on the rear of the wishbone. Front one goes into a captive.
    I cracked off the bottom nuts for the ball joint first, before splitting the ball jing from the hub. If you take the wishbone off without doing this, it might be difficult to get them undone.
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Cheers,
    got them done yestarday, had to go and find a blow torch to give the ball joints a heat to get them out though, bloody sore today though, just got to remember i am getting OLD>>>
    ps are all cast wishbones the same size?? cars now sitting with plenty of toe out.
    mark
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by epox View Post
    Cheers,
    mark
    Nope they're not all the same size. Earlier wishbones on the S3 had a smaller bush (on the front inner IIRC)
    Do 2000 onwards S3's have different front wishbones?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    epox's Avatar
    Oct 2012
    Glasgow
    600
    sorry ye new about the rear bush size, was wondering about the over all dimensions and yes could have checked before fitting but i an a numpty.
    cheers
    mark
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    cheers
    mark
    I've had them side by side and on top of each other when I was replacing mine and didn't see any major differences other than the bush size
    2000 S3 APY
    Mar 2013
    Devon
    616
    I gained about 10 degrees of toe out when changing from small to large bush arms.
    They don't look much different side by side, but its enough to throw things out a lot.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    was wondering about the over all dimensions.
    The topic has been discussed in some great depth before btw
    tt wishbones
    2000 S3 APY
  1. Any advice on front arb replacement
    By danpayneuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 09:00
  2. Front Wishbone swap- how hard?
    By chrisb in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2006, 20:43
  3. Front Wishbone Bushes
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2005, 09:13
  4. Help with front wishbones
    By imported_Jamesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2005, 11:55
  5. A3 sport front wishbone angles
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2004, 11:17
