Badger5AH Fabrications
Results 1 to 28 of 28
Thread: ETKA problem
    May 2003
    renfrew
    32
    ETKA problem
    I have just got a copy of etka disc from a fellow Scottish member, but having a problem trying to opening it as it keep saying " Hard Lock Error 14 ,Code :306 ".
    Can somebody please help me get around this problem?
    Kenny
    Scotland
    154
    Re: ETKA problem
    EKTA as delivered to the dealers is protected by a dongle. This is why you are seeing this message, the program is looking for dongle but cant find it. There is a way around it, but you need to download a crack which replaces the lexhdl5.dll file
    regards
    May 2003
    renfrew
    32
    Re: ETKA problem
    I have got the crack with disc,but don`t know what folder and what file to put it in ,if you could tell how to do it ,it would be great
    thank Kenny
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: ETKA problem
    replace the lexhldl5.dll and the winetka.exe that are on your c:\et_prog with the ones in the (cd)\crack directory of the disc [img]/ubbthreads/images/graemlins/grin.gif[/img]
    RAPS3's Avatar
    Moo Moo Land
    1,089
    Re: ETKA problem
    Here you go heres the installation file for Etka, have fun -
    Installation Instructions.
    Please be sure to have hidden files showing. In "My Computer" and "Windows Explorer",
    Go to "Tools", click "View Tab" and make sure that "Show hidden files and folders" is
    checked.
    1)Install using the ETKSETUP.exe icon.
    2)Copy LEXHDL5.DLL from the cd to x:\et_prog directory.
    Where x is the harddrive that the program is installed.
    This will bypass the Hardlock dongle.
    3)Create a shortcut to WINETKA.exe on your desktop, from the et_prog directory above.
    You now use this icon to run the ETKA not the one it installs in the start menu.
    Or it will not run smoothly.
    4)Your display must have the ability for 1024x1280 resolution or you won't be able
    to see the whole screen. 17" inch or larger is recommended.
    5)System Requirements: Win95,98,NT,ME,2000,XP; Pentium II or higher;
    400 megabytes of harddrive space; CD-ROM Drive; Resolution of 1280 x 1024.
    Super detailed instructions for those novices on the computer:
    checked.
    - Put CD into CD drive
    - Go to Windows explorer
    - click on CD rom drive (usually D drive), it should say EKTA next to the
    drive.
    - you should see a bunch of folders, A, D, E, etc. 4th icon from the bottom
    should read "ETKSETUP.EXE", click on that.
    - this should put you into the set up mode. Install the English version.
    Make sure that you install it under the "C" drive folder, once it is done
    installing, you still need to do 2 more things.
    1) go back to Windows explorer and click back on D: , the very next to last
    item there is LEXHDL5.DLL, right click and "copy" it. It is right above the
    read me. txt . Then go to "C" drive and find the folder "et_prog" folder,
    click on folder and then paste LEXHDL5.DLL to that folder. This is very
    important!!
    2) After you do that you can now create a shortcut. Right click on
    WINEKTA.EXE in the "et_prog" and highlight and click on create short cut.
    This will create a shortcut for you in the same folder. Make your window a
    little bit smaller so you can highlight the new shortcut and drag it to your
    desktop. Once there you can change the icon if you want to the ETKA icon
    which in the "et_prog" folder and also change the name if you like by right
    clicking and renaming.
    YOU must ALSO make sure, that your screen is set to a 1024x1280 resolution.
    You can do that by right clicking on your desktop and go to settings and
    then slide the resolution over to 1024x1280. You must be in this resolution
    EVERY TIME you are working with EKTA.
    TIPS FOR WORKING AT 1024x&768
    If your monitor only supports 1024x768 resolution do not dispair! ETKA will still run just fine and you will still be able to exploit its functions, but these tips may help you on your way.
    Once in the VW model select screen, the following VW models are accessed by pressing the down arrow on the keyboard followed by 'Enter':
    TR [transporter]
    TRSY [transporter synchro]
    T2 [type 2]
    T2SY [type 2 synchro]
    T3 [type 3]
    VE [vento and jetta]
    VESY [vento and jetta synchro]
    1200 [beetle]
    To zoom to a masked part of an illustration, simply click on the 'Functions' button [upper right hand side of screen], and then activate 'Illustration Zoom'.
    To scroll through the parts listing for a particular illustration, simply click on the 'Page Text' button [uppermost on the screen].
    To close any window of which you cannot see the 'ESC' button, simply press 'ALT F4' on your keyboard.
    To switch between ETKA and your other Windows programs, press the 'Microsoft' button on your keyboard [between 'Ctrl' and 'Alt'] to reveal the Taskbar.
    Remember that ETKA is the excuse you always needed for that 19" TFT monitor!!!
    May 2003
    renfrew
    32
    Re: ETKA problem
    i have follow your guide,but still cann`t get the illustration to work ,keep get hardlock not persent code 304 .Please can tell me how to get around this
    thank Kenny
    Khufu's Avatar
    5,693
    Re: ETKA problem
    Maybe it was a dodgy source of disc [img]/ubbthreads/images/graemlins/crazy.gif[/img] As far as I'm aware, the copy I sent to AL_B worked ok though. Not sure what the problem is.
    May 2003
    renfrew
    32
    Re: ETKA problem
    will try and reinstall it again and see if this work, if not will have to meet up with and see if there anything you can do
    Khufu's Avatar
    5,693
    Re: ETKA problem
    No problems. Until then just ask Gambba, I'm sure he quotes from it like a minister does from a bible [img]/ubbthreads/images/graemlins/lol.gif[/img]
    May 2003
    renfrew
    32
    Re: ETKA problem
    Praise the Lord [img]/ubbthreads/images/graemlins/angel.gif[/img]
    cheer speak to you soon
    1,361
    Re: ETKA problem
    [ QUOTE ]
    [/ QUOTE ]
    Indeed I do! So rise up and thank ye lord for bleesin' us with de holy ETKA, for if it was not for the power that ETKA beholds we could not part water, we could not fit 4 bar FPR's, we could not verify the number for sunglass holders and nor could we check if them stupid plicks at the Audi dealer have got the right part....so praise the Etka.
    May 2003
    renfrew
    32
    Re: ETKA problem
    Gambba, we know you are the lord of ETKA ,can you please tell me how to get around the "hardlock not present code 304" when trying to view the part pictures.
    RAPS3's Avatar
    Moo Moo Land
    1,089
    Re: ETKA problem
    Lord Gamba of Etka [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    Sounds like someone from Star Wars
    Khufu's Avatar
    5,693
    Re: ETKA problem
    conjures up pictures of an Ewok [img]/ubbthreads/images/graemlins/lol.gif[/img] I take it you didn't run the hardlock.exe by accident. If you double clicked it, that may be the problem. If you did, maybe un-installing it and re-installing it may help. I couldn't see any entries in the registry that would keep any information that could cause any problems.
    1,361
    Re: ETKA problem
    Kenny,
    The only way I can get the hardlock error to occur is by not putting the LEXHDL5.DLL file into the ET_PORG folder.
    Basically I install the full version and then take the LEXHDL5 file and put it into that folder and the whole thing works without a problem, this works on both win 98 and 2000.
    May 2003
    renfrew
    32
    Re: ETKA problem
    Gambba,
    I did what Khufu said and still nojoy ,but i am running my pc on XP ,I think there is some problems installing it on XP.
    What mpg do you get when running the car with no A/C on, i am only get about 28-29mpg (1.8T Sport).just trying find out if the maf need a clean before going to a dealer to get it checked out
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,002,031
    Follow Administrators On Twitter
    Re: ETKA problem
    [ QUOTE ]
    Gambba said:
    Kenny,
    [/ QUOTE ]
    or get a dongle [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    May 2003
    renfrew
    32
    Re: ETKA problem
    Where do i get one of them from and how much
    May 2003
    renfrew
    32
    Re: ETKA problem
    Gambba, I work on a servicing fire and intruder alarm systems all over scotland and what about yourself.Try to PM but you have it switched off
    May 2003
    netherlands
    35
    Re: ETKA problem
    What can you do with this program?
    Administrator
    Oxfordshire
    1,000,002,031
    Re: ETKA problem
    [ QUOTE ]
    [/ QUOTE ]
    I think they're about a grand! [img]/ubbthreads/images/graemlins/crazy.gif[/img] [img]/ubbthreads/images/graemlins/jawdrop.gif[/img]
    May 2003
    renfrew
    32
    Re: ETKA problem
    well i will sell the car so i can buy it [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Khufu's Avatar
    5,693
    Re: ETKA problem
    The program shows exploded diagrams of all VW and Audi parts since about 1979 (Cant rem. exactly) along with the part numbers. It is handy for ordering parts and getting the right bit! Can also be used to check the difference between models of same car and see if parts can be interchanged.
    Administrator
    Oxfordshire
    1,000,002,031
    Re: ETKA problem
    [ QUOTE ]
    [/ QUOTE ]
    but if you become a VAG dealer I think they're alot cheaper! [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    May 2003
    renfrew
    32
    Re: ETKA problem
    [ QUOTE ]
    Wando said:
    [ QUOTE ]
    [/ QUOTE ].
    i think i will buy another honda at least i could get they part disc to work [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    Little_Si's Avatar
    UK
    64
    Re: ETKA problem
    Which version you using. I have V6 which, I beleive, works OK under XP.
  28. #27
    Khufu's Avatar
    5,693
    Re: ETKA problem
    I will get a chance to meet up with you and your laptop Kenny and see what I can do.
  29. #28
    May 2003
    renfrew
    32
    Re: ETKA problem
    Cheer ,just let me know when
