AH FabricationsSky Insurance
Results 1 to 11 of 11
    Jan 2014
    Worcester
    183
    Fitted new standard DV now car unhappy
    Hi, I got a standard DV from my local vw garage today and promptly replaced my leaky forge split r but on the drive back the car seems to be surging or if you let off a little it jolts, the car was quite smooth with the forge on but not so much. I've changed the dog bone mount so its not that.
    It also pops when you blip the throttle and the engine almost dies when you pull up to a stop or rev it then let the revs settle.
    Help lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    Got a big leak somewhere I suspect...
    <tuffty/>
    Jan 2014
    Worcester
    183
    Chance the brand new dv could be faulty?
    Attached pic so people know the part number.
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Might be a stupid one but have you put it on the rite way
    Jan 2014
    Worcester
    183
    I think so, high pressure side going into the side of the valve and vacuum pipe on top
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    The other thing it could be is the split-r had a big enough leak that the adaptions are out of whack... the ecu takes a little while to re-adjust... if you have VCDS you could check for fault codes just in cas, copy them to notepad then reset them... it will reset the fuel trims and may fix the issue
    <tuffty/>
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Turn it around than and see what happens
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    The OE DV doesn't fit the same way the split-r does... bottom (opposite of the small vacuum inlet) goes into the TIP and boost goes into the side
    <tuffty/>
    Jan 2014
    Worcester
    183
    I thought that and did wonder if the car made compensations for leaks etc, any way to reset this without a vcds? I bought a cheap one off eBay but it didn't work surprise surprise. Probably the first time in years the car has had no vacuum leaks as I've replaced all the small vacuum pipes with silicone ones because they just crumbled when touched
    Jan 2014
    Worcester
    183
    Car is now happier but not perfect, still almost dies and revs up and down after a battering or coming up to a roundabout
    russwuss's Avatar
    Feb 2013
    424
    Quote Originally Posted by lol4fun View Post
    you have anyone local that would lend you a MAF sensor? could give that a try...
  1. Local garage fitted new TIP and now problems :(
    By MILF in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2013, 18:46
  2. Wash car, and fitted new numberplate LED's and new Sidelight LED's and Bulbs
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th February 2012, 05:46
  3. Fitted new seats now airbag light on.
    By Ian_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2012, 16:30
  4. Replies: 29
    Last Post: 14th March 2010, 14:17
  5. Replies: 5
    Last Post: 18th January 2010, 23:36
