JMB RetrofitsEM Tuning
Results 1 to 11 of 11
Thread: leaking water
    audiholic ste's Avatar
    Aug 2013
    164
    leaking water
    After a bit of help finding out what is leaking on my s3 . It seems to have crack on something under the y shaped pipe that is part of pcv system . What I want to know is this the thermostat housing and what part number is it ? . All help is welcome .
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    It sounds like your describing the coolant elbow on the end of the cylinder head.
    This isn't the stat housing no mate, but it is a common failure point and cause of leaks.
    part numbers do vary, so your best bet is to remove yours and take a look, but typically it'll be 06A 121 132 followed by a letter, in my case Q, like this:
    URO Parts 06A 121 132Q Cooling Hose Flange with O-Ring | eBay
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its not the thermostat housing, but the pipe you mentioned is prone to splitting on the seams, about £15 from Audi
    Aug 2013
    164
    Cheers prawn and Dave my working day has finished early again . So I will get it stripped off and replaced this afternoon . In what appears to buy a very nice day in the northwest the sun is out .
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    Its a common fault and a pain to find, well it was for me as it was a hairline crack on mine!!
    Aug 2013
    164
    Bleeding call outs meant I didn't get the new one fitted but I got the old one off it was buggerd . I'm half way there .
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    Changed mine the other week, might as well do an N249 and SAI removal while you're at it. I kept the pump in place, but removed all of the pipes.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel|Stage1Map
    WANTED: Audi A4 B7 or MK5 5Dr Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Aug 2013
    164
    Is the sai part of the n249 delete .
    Mar 2013
    Devon
    622
    Quote Originally Posted by audiholic ste View Post
    No, two different systems, and can be deleted individually.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    Sai removal guide
    N249 Bypass How To (2000 S3 - but same for many)
    I didn't want to mess about in the freezing cold with removing the pump and soldering so it's stayed in place. I still have an error code but it doesn't bother me. In my mind, less stuff that can go wrong the better.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    295
    Ahh this is my issue. Thanks guys.
    Damn hairline crack... only visible when looking and squeezing water pipes!
    Blimin oil breather hose from under the inlet that goes over the top of this has torn too... ffs!
    2001 AMK Dolphin Grey S3
  1. S3 leaking water now loud climate control. Video attached.
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2013, 15:42
  2. Boot leaking water
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2013, 11:34
  3. S3 Leaking water In Passanger Footwell
    By Jacko4130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2009, 10:56
  4. S3 problems with leaking water
    By nicklght in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2009, 11:23
  5. a3 leaking water into car ?? any ideas
    By nick1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2007, 12:41
