AH FabricationsJMB Retrofits
    Richierich84's Avatar
    Feb 2014
    Rainham
    20
    No rear break lights
    Hi having abit of a problem! I have no break lights Iv done all the obvious Iv changed the bulbs first no luck then checked the fuse it was fine but changed it anyway and checked the foot peddle switch everything seems fine but they still won't work , the lights work but the stop tail part of the bulb is not working. Has any1 got any ideas thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    Brake switch has two circuits... one for the ECU and one for the lights... faulty brake light switch typically throws a fault code... scan the car and see but test the switch again too
    <tuffty/>
    Feb 2014
    Rainham
    20
    <tuffty/>
    ok cheers mate will check switch again tomorrow
  1. Chaning rear break light bulb on my A5 07 MODEL NEED ADVICE
    By a5_onroad in forum A5/S5/RS5 Forum
    Last Post: 10th April 2013, 11:53
  2. Front Signal and Rear Brake Light Errors
    By vpg_ii in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th December 2004, 05:34
  3. Rear Brake Light DIS warning
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2004, 17:19
  4. rear fog light
    By sllt1776 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2004, 00:45
  5. Rear tail lights
    By nelly in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 16:07
