EM TuningBadger5
Results 1 to 10 of 10
    Feb 2014
    6
    changed cluster on audi now will not start
    hi guys i changed the cluster on my audi a3 2002 8l model and it starts when you hook it up to the car then after a day the immobilizer kicks in and when you turn the switch the milage lights and other screens go blank and it doesn't allow the car to start i have formated the clocks and reprogrammed them and the same issue appears to be happening...... NOTE; there is no car on the clocks with key when i try to start it so i'm guessing it's not a key issue please help !!!!
    thanks
    Mar 2013
    Devon
    611
    Faulty cluster? Why did you change it?
    Feb 2014
    6
    ll the diing wrong and bouncing up and down got the new one from a breakers it works fine when started the new one !!!
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Has it been coded into the car
    Feb 2014
    6
    yes it has been coded that is why it starts to begin with but when you leave it for a while it doesn't start and the milage and time bit of the cluster switches off and it doesn't start !
    May 2012
    RETFORD, NOTTS
    1,753
    Does it start then cut out? Did the immolight work during coding? Formatted? Is it a vdo clock or something else and did you happen to use vag tacho or clone of commander?
    Where abouts are you and what does vcds say?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Feb 2014
    6
    Quote Originally Posted by @udi A3 View Post
    im not sure to be honest buddy ..... the guy doing it for me put the new cluster on and the temperature gauge was stuck on 90 degrees so he took the gauge off the old one and replaced it into the new unit and re- installed it and he says when he hooks it up it starts and runs fine then after a while of it being switched off say 12 hours when he goes to turn the engine again the clocks losses all the writing on the screen and it doesn't start..... but when you take the back fuses off and put them in again it starts fine again apparently... he is from what i know using a vag tacho but i'm not so technical myself when it comes to electrics so not sure if it is a vdo clock.... or what vcds is but i can ask him ....
    he is now telling me that the new clocks have some kind of problem and it is nothing that he has done wrong and it is the chance you take with a second hand unit but any help you can give me i would be most indebted to you although i don't live in the uk any longer i feel a bit like i'm being taken for a ride if you know what i mean !!! thanks for your help in advance !
    Mar 2013
    33
    I'd say the clusters knackered. The cluster is the CAN gateway so when this fails she's got no hope of running...
    May 2012
    RETFORD, NOTTS
    1,753
    What was the fault with original clocks? Try finding sa vdo replacement the jeager u have a notorious for failing. Trying to copy eeproms over, which is what it sounds like he did, will not work. Especially not with vag tacho! Vag tacho is good to read the pin/skc and vcds to program them in.
    Feb 2014
    6
    the original clocks were not working all the dials were wrong and jumping up and down speedo rev counter petrol gauge and thermostate !!
  1. Audi S3 speedo removed and refitted now will not start HELP PLEASE
    By jacks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2014, 01:18
  2. 2005 audi a4 2.0tdi S-Line - Loss of power, Smoke from exhaust & now will not idle
    By cshoreduffy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th June 2013, 15:20
  3. Dad decided to remove his fuses with battery still connected, now will not start...
    By chris.vincent3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2013, 08:13
  4. Audi UK Will not warranty turbo failure on S4
    By ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2006, 11:41
  5. 2003 A4 1.8T - Car Will Not Start When It is Cold
    By laura in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2004, 17:39
