JMB RetrofitsSky Insurance
Results 1 to 11 of 11
    Nov 2013
    84
    coolant leak from flange
    hello
    i have an coolant leak from the coolant drain flange.
    can i fix it or change the all flange?
    A3 1.8T
    decat stage 1 206 HP
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Pics?
    You mean the one on the bottom of the radiator?
    <tuffty/>
    Nov 2013
    84
    yes where the drain plug
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    This you mean?
    <tuffty/>
    Nov 2013
    84
    yea
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    I assume the tap is screwed in and locked off ok? where is the leak coming from exactly?
    In answer to your question, this part is clipped onto the radiator and is available from an Audi dealer... part number should be embossed on the part
    <tuffty/>
    Nov 2013
    84
    the leak is from the drain hose
    my uncle said its maybe the o ring seal
    can i replace the o ring?
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Quote Originally Posted by aviel131 View Post
    Possibly.. I doubt the main part is expensive... stuff like that normally isn't as expensive as you think... never taken one apart so no idea it it can be replaced... doubt Audi would list the o-ring for it anyway so you would have to take it apart to find out and risk further damage.. then you will need to find an o-ring the right size...
    I'd get a price from a dealer first dude then decide
    <tuffty/>
    Nov 2013
    84
    dealer is expensive
    does it have aftermarket one?
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    See... cheap
    New Genuine - VW Audi Seat Skoda - Water Hose Coupling - 6Q0122291F | eBay
    Try searching for part number 6Q0 122 291 F
    <tuffty/>
    A3 TQS
    Jul 2013
    Devon
    163
    6Q0 122 291 F £4.51+vat from the dealer
  1. Coolant leaking from the coolant tank A4 B6 1.9 TDI
    By delc83 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th December 2013, 11:01
  2. Coolant leak from trans tunnel and pics of cleaning battery drain.
    By nogmeg in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th July 2012, 18:27
  3. Coolant temp. sender flange leaking, why?
    By 2.0 8v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd July 2010, 22:25
  4. remap and leak from rear coolant flandge
    By justintime1026 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th November 2008, 18:01
  5. Coolant leak from under my car?
    By DIA in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2007, 13:18
