Monster MotorsportVolks Autos
Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By <tuffty/>
  • 1 Post By JUS3IN
Thread: how to test a dump valve?
    Jan 2014
    Worcester
    185
    I have a problem, when I put a standard recirculating valve on my car it chatters like its not opening and I've tried this with 2 but when I put a forge one one it sounds like its leaking under boost. How can I test them?
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    430
    The simplest way to test is to push the piston up by poking something through the bottom, then create a seal with your thumb over the top where the vac hose would go and see if the piston returns... If it does then it's buggered
    Apr 2013
    JHB, South Africa
    168
    +1
    Same way to test that was told
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    If the Forge one (assuming its a 007 or 008 and not the crappy split-r) has an o-ring on the bottom of the piston then it shouldn't leak at all under boost... if its a metal bottomed piston then get a service kit for around 15 quid that has the new design piston in or just buy a new OE valve
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    ...and there are two threads in the FAQs about DV's and testing stuff etc...
    <tuffty/>
    JD09 likes this.
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    <tuffty/>
    I just did this... Goodbye old 007P. eGay here it comes!
    Eddie S3's Avatar
    Jul 2011
    Aberdeen
    108
    My two OEM ones are still both making a hooting noise Stuck the leaking 007 back on for now
    This was me testing my 007
    2002 Audi S3 261bhp
    Miltec Exhaust, Badger5 TIP, Stage 1 Remap, 007P DV.
    Todo: Fit LCR Splitter, FMIC, Clean.
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by Eddie S3 View Post
    Is that not leaking from the pipe? Difficult angle to tell!
    Eddie S3's Avatar
    Jul 2011
    Aberdeen
    108
    It was a while ago I recorded that but it was definitely leaking out of the bottom
    2002 Audi S3 261bhp
    Feb 2012
    1,121
    Under how much pressure was that. And how long is that pressure on the dv? Is it constant while the turbos spinning? I know nothing about how this works im sure im going to look stupid here.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Pressure on the DV is there while 'on boost' dude... once throttle is closed then there is vacuum on the top that lifts the valve and release the pressure back into the TIP... if air is leaking past (as per the vid) thats air thats not getting to your engine and this equals power loss
    <tuffty/>
    Feb 2012
    1,121
    Wow thats just incredible. I think im going to sell my 007 and get an oem. Sound wise?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Forge have revised the piston so should no longer leak... get a service kit for 15 ish quid which includes piston, o-rings and grease and treat it...
    <tuffty/>
    Jan 2014
    Worcester
    185
    All 3 the piston drops as soon as I release it from pushing it up while blocking the vacuum end. I can blow through both the standard vacuum ends and hear it leaking. The forge one is a split r, I bought it before doing any research -.- lesson learnt
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    make sure they are on the right way round aswell lol!-)
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Jan 2014
    Worcester
    185
    Which way around is the proper way?
    Ordered a standard DV from my local vw dealers today, only £37 including vat.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Quote Originally Posted by lol4fun View Post
    Don't bother testing the split-r... they just leak... period!
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    as you had a split r im thinking that had the vacuum pipe horozontal, the stock dv's are vertical as tuffty taught me lol... so on the stock the vacuum pipe points at the sky.
    lol4fun likes this.
    Jan 2014
    Worcester
    185
  1. how does atmospheric dump Valve on my 1.8t work fine???
    By valyboi in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2014, 19:11
  2. Can I test my Oem diverter valve? (Dump valve)
    By SCHOLESY83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2013, 08:58
  3. How To: Charge pipe to dump valve silicone hose for 9
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2011, 20:39
  4. how to test a dump valve??
    By d18ony in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2008, 14:12
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
