Sky InsuranceVolks Autos
Results 1 to 8 of 8
Thread: Audi S3 smoking
    Jan 2014
    7
    Audi S3 smoking
    Hi recently changed head gasket on car then took it for a drive and noticed it was smoking like oil smell the car dident smoke before hand just wondered if the timing could be tooth out or anything as I've run out of ideas
    Last edited by <tuffty/>; 5th February 2014 at 18:57. Reason: Please don't use caps...
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Could have too much oil. Check the oil. Does it smoke constantly or just when boosting?
    Ninja edit: A little more info on your car etc would be good
    Jan 2014
    7
    2002 Audi s3 bam engine the dose not seem to smoke.till hot I've dropped old oil and put fresh in it I changed manifold on car so had head of and put new head gasket on New bolts ect but I never had head skimmed as it was fine befor hand but wondering if I should
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    There will always be a small amount of oil burning off from the exhaust etc after doing work like this... oil gets everywhere and it typically all burns off after a short time..
    Other than that its tricky to say what else could be wrong as headgasket changes are pretty invasive/involved jobs requiring loads to be removed/refitted...
    Go back over everything and double check its all connected as it should be... typically oil smells come from damaged PCV hoses
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Make sure the engine can breathe i.e catch can blocked or pipes have not collapsed
    Jan 2014
    7
    IMAG0047.jpgIMAG0047.jpgIMAG0047.jpgIMAG0046_1.jpg found split in this pipe all gunky as well
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Maaan I'm so hungry and we're having our kitchen refitted and you go post pictures of food.... (what ever that is...)
    I thought I'd be safe in ASN.
    That's your N75 isn't it?
    Jan 2014
    7
    No its oil breather pipe hope its that
  1. Audi Problems :( black smoke, loss of power, siren/whistling sound.
    By V16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 20:20
  2. Audi A6 2.5Tdi excessive white/grey/slight blue smoke, loosing coolant
    By ash1983 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th February 2010, 21:13
  3. smoking audi A4 turbo s line 190
    By jamichelle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2009, 14:15
  4. Audi A4 TDi V6 Quattro running lumpy and smoking!
    By James Carlon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2009, 09:23
  5. AUDI A6 Rattling Noise & Blue Smoke- HELP
    By grigor in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th December 2007, 23:13
