Chris NottEM Tuning
Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By JUS3IN
  • 3 Post By gingerben
Thread: What intercooler to buy
    Snuff's Avatar
    satan's driver
    Aug 2011
    darkest caerphilly
    56
    I got a 2003 S3 and im looking to get an intercooler. Seen the forge one but not keen on the price , there must be other good makes /companies that do them for my car... been off here for a while so a bit out of touch and blinded by science
    Any help info or ideas welcome
    Feb 2006
    Lincolnshire
    714
    Have a read of this thread first, and come back if you have any more questions.
    I'm pretty sure most of it is in there to be honest...
    AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Im sure there is an offer running at the moment for the wellycooler on the forum homepage.
    Snuff's Avatar
    satan's driver
    Aug 2011
    darkest caerphilly
    56
    Cheers dude.... thats been a massive help
    Snuff's Avatar
    satan's driver
    Aug 2011
    darkest caerphilly
    56
    cant find the page for the welly cooler
    Nilz's Avatar
    Apr 2006
    10,062
    Sorry mate, there was an ad earlier or yesterday, but cant seem to find that now either.
    Have a look at the wellycooler info, plenty on here.
    Jan 2014
    106
    Is this the right sort of kit? http://bit.ly/UvRBVJ
    Just wondering if that has the correct bends and number of pipes?
    Anybody have any experience with this
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,464
    Quote Originally Posted by Bennys3 View Post
    No... wrong one entirely...
    All the info is in the FMIC thread posted above dude... various members have documented their fitting and pipe work... its a bit of a read but worth it...
    <tuffty/>
    Feb 2014
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    done my welly cooler with this;
    welly cooler
    2x 90 degree bend 76mm to 63mm reducers silicone
    2x 90 degree bend in 63mm silicone
    2x 90 degree alloy bend 63mm
    2x straight alloy hose couplers 63mm
    +clips
    will need a 4 inch angle grinder and carbon discs to cut the alloy crash bar and read up on the bumper removal refit in the stickys.. a dremal with cutting discs would be hand too to cut the fog light surrounds.
    NOTE I LOST MY FOGS TO HAVE SHINY PIPES!-)
    sssline likes this.
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    like to add i cut my crash bar very snug and then just inserted a nut either end in the holes in the welly cooler and used heavy duty cable ties to hold it... it is actually really solid although most people less cowboy than i might spend a bit more time and make some brackets.
    Jul 2011
    7
    IMG_8696.jpgIMG_8698.jpgIMG_8704.jpgIMG_8713.jpgIMG_8714.jpgIMG_8725.jpg1891068_10152157733801293_1441195287_n.jpg
    Ah Fabs V2 Cooler is 100% best option and best fit for me, Cooler was £380 and pipes to fit were about £60.
    turbo outlet can be far to hot to touch and inlet will be frezzing, and after badger stage 2 this thing is awesome
    Could have cut the crash bar a little less but was a little trial and error.
    Very cool cooler.
    <tuffty/>, StaceyS3 and sssline like this.
    Nov 2013
    Heath Hayes
    930
    Thats a nice install, bit more expensive than an E-bay solution but you get the maximum size intercooler into the space and maintaining the crash bar has got to be good. It holds the front of the car in some kind of alignment, connecting the rails and stiffening the front of the car.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,464
    Quote Originally Posted by desertstorm View Post
    Karl.
    I designed this cooler to fit as easily as this and keep the car looking as OE as poss... a little trickier to pull off with a welly cooler but not impossible... that said the welly cooler does work well
    <tuffty/>
  1. what shall i buy for it....
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th October 2006, 13:24
  2. What made you buy your S3/A3
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2005, 14:19
  3. If you had 10k... what would you buy next?
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2005, 12:40
  4. what tyres to buy
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 23:02
  5. ok what do i buy ?
    By tomknightley in forum Detailing
    Last Post: 18th November 2003, 01:07
