AH FabricationsChris Nott
Results 1 to 9 of 9
    Nov 2004
    Tonbridge, Kent
    912
    resetting the service reminder?
    Hi, I got my car serviced at a local garage a while ago, but now the service reminder is flashing up saying 1000miles to service. Is this something I can turn off? Other question is will it be a problem when it passes the deadline?
    Nov 2004
    Tonbridge, Kent
    912
    Re: resetting the service reminder?
    Anyone? Its a bit annoying now whenever I turn the car on.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Someone with Vag Com would be able to turn it off for you.
    Nov 2004
    Tonbridge, Kent
    912
    Nice one!
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    there is a way of doing it using the milege reset or the clock one, ill have to look it up on here, and ill get back to you
    Nov 2004
    Tonbridge, Kent
    912
    cheers
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    The procedure is explained in vehicle handbook.
    Aug 2003
    North West
    118
    Rob,
    If your on AVS servicing schedule then the only way of resetting it AND remaining on AVS schedule is through VAG-COM or official dealers VAS5051. You can use the manual technique thro using the insturment pod buttons, but this then takes you off AVS on to standard fixed servicing ie, every year or 10000 miles.
    Nov 2004
    Tonbridge, Kent
    912
    Hi, I am servicing it every 10000miles like a caring audi owner should.
    Cheers for the info guys, will sort it myself.
    Rob
