Monster MotorsportChris Nott
Results 1 to 9 of 9
Thread: Lambda sensors
    Jan 2014
    south wales
    92
    Lambda sensors
    Getting a few faults code for lambda sensors so though if just replace them
    are they both the same or does any1 have part numbers I have a 2000 a3 1.8t aum engine code
    also where is the connections located
    thanks
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    soak them in vinegar see how you get on, it worked for me
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    What are the codes? don't assume a fault code for a sensor means it is faulty...
    <tuffty/>
    Jan 2014
    south wales
    92
    Address 01: Engine Labels: 06A-906-032-AUM.lbl
    Part No: 06A 906 032 DK
    Component: 1.8L R4/5VT 0001
    Coding: 11500
    Shop #: WSC 00647
    VCID: 6ADB242A16DFE44E2A7-517A
    WAUZZZ8LZ1A025983 AUZ7Z0Y1572803
    4 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1116 - 35-00 - Open Circuit
    17608 - Boost Pressure Control Valve (N249)
    P1200 - 35-00 - Mechanical Malfunction
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 35-00 - Performance too Low
    17522 - Oxygen (Lambda) Sensor; B1 S2
    P1114 - 35-10 - Internal Resistance too High - Intermittent
    Readiness: 0010 1101
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Yeah... fair point... these suggest both are not happy...
    This typically happens when you have done an N249 bypass or if not you have a faulty DV
    <tuffty/>
    Jan 2014
    south wales
    92
    Yea might just order 2 new as got mot next month
    Jan 2014
    south wales
    92
    Is the pre and post cat sensors the same or are they different?
    Jul 2011
    wiltshire
    135
    Don't quote me but I'm pretty sure the post and pre work on different perameters, so are both different, I'm sure though someone can clarify!??
    Jan 2014
    south wales
    92
    I'll take them both out and I'm sure I can take them to motor factors and get what I need cheers
  1. Lambda Sensors
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2005, 11:34
  2. does anyone know how to replace the Lambda sensor?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 23:26
  3. Engine Coolant temp and Lambda sensor
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 9th March 2005, 13:05
  4. Help Lambda Sensor
    Last Post: 13th January 2005, 19:14
  5. Lambda Sensor
    By Speedo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2004, 09:23
