EM TuningBadger5
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By DPM
  • 1 Post By Bad Sir Culation
Thread: Suspension choice
    Simon_S3's Avatar
    Dec 2012
    West Sussex
    89
    Suspension choice
    Does anyone know what the Koni STR.T kit is like as i do quite a few track days now but dont want to lose too much comfort either?
    Koni 25mm STR.T Lowering Springs & Shocks Suspension Kit S3 8L 1.8T Quattro 01/99> - £465.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts f
    I can't decide between these or the group buy for the Bilstein B8's?
    2002 S3 8L, BAM, 85,000m, B5 map, B5 tip, K04, small port head, jetex filter & heat shield, Xs mani v3, 3" d/pipe, 200 cell cat, miltek non res cat back system, Sachs DMF & 4 paddle clutch, PCV delete & catch can, N249 delete, AH fab v2 intercooler, silicone boost hoses, Liquid gauge, LCR Brembo's, DS2500 pads, Braided brake lines, Motul RBF600 brake fluid, LED bulb kit, aero wipers, manifold heat shield, Aquamist WMI, Mocal oil cooler, Forge short shifter, Dave's rear tie arms. 295bhp/274lbft.
    Nov 2011
    Leeds, UK
    287
    I'll be running it after the weekend so could tell you in a couple of weeks.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,296
    The Koni kit is a good option and excellent value for money.
    What springs would you be running if you went for the B8's?
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Quote Originally Posted by DPM View Post
    I'm in the same boat - Damian, it would be H&R as per the recommendation. Thoughts/comparisons between the two?
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    I run this suspension, absolutely fine as a daily driver, couldn't comment on for track use. Should note these aren't adjustable in height or damping
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Simon_S3's Avatar
    Dec 2012
    West Sussex
    89
    Hi Damian, Tuffty runs Apex springs so either those or H&R whichever keeps the most comfort?
    Simon_S3's Avatar
    Dec 2012
    West Sussex
    89
    Quote Originally Posted by Bad Sir Culation View Post
    That would be great.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,573
    Quote Originally Posted by Simon_S3 View Post
    This may help you?
    Audi S3:Eibach vs H&R vs Apex lowering springs.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,296
    When I had my S3 8L I ran it firstly with the Bilstein B8 dampers and H&R springs and then changed over to Eibach springs.
    I personally found the H&R springs a little stiff, as I do with the Apex after being in S3's with them fitted, and found the Eibach's much more forgiving and well matched to the dampers.
    The STR.T kit is a good everyday driver kit but you'll get a much more refined ride with the Bilstein mono tube B8 dampers.
    JD09 likes this.
    DPM Performance
    T: 01207 561606
    Feb 2009
    Telford
    31
    I'd echo what Damian has said, i originally had B8 dampers with Apex springs which lowered my S3 by approx 40mm, it looked the business lowered by 40mm but didn't suit the roads i have to use daily (quite rough and uneven, in the winter pot hots can appear through the day and although they get filled in quickly there never filled in flush with the rest of the road) the ride was just too hard for rough roads and i could never get over a speed bump without scraping - handled like a dream around the corners though!
    I sold the apex springs to Tuffty who seems happy with 'em and replaced them with Eibach springs which only dropped the car 25mm over the standard setup but we're much more forgiving on rough roads and are still pretty good around the corners
    Mar 2010
    89
    Quote Originally Posted by mulli01 View Post
    I'd echo what Damian has said, i originally had B8 dampers with Apex springs which lowered my S3 by approx 40mm, it looked the business lowered by 40mm but didn't suit the roads i have to use daily (quite rough and uneven, in the winter pot hots can appear through the day and although they get filled in quickly there never filled in flush with the rest of the road) the ride was just too hard for rough roads and i could never get over a speed bump without scraping - handled like a dream around the corners though! I sold the apex springs to Tuffty who seems happy with 'em and replaced them with Eibach springs which only dropped the car 25mm over the standard setup but we're much more forgiving on rough roads and are still pretty good around the corners
    thats my issue - with so many speed bumps around where i live and near to work - I'm loathed to lower my car but would love to.
    Nov 2011
    Leeds, UK
    287
    Well after only a day with the STR.T dampers and H&R springs, I can honestly say I am very impressed with them. Drove snake pass yesterday after having had the car aligned and it was awesome. Really great handling and not bad at all over poor surfaces.
    Sure, the Bilsteins might be a bit better overall, but for £4XX these things are great. Very, very pleased.
    WorkInProgress likes this.
  1. suspension choices
    By s3_kev in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2013, 11:19
  2. Suspension choices...
    By Pubemammal in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2013, 23:10
  3. Suspension Choice, what did you go for and why?
    By 97catalunya in forum New A3/S3 (8V Chassis)
    Last Post: 10th June 2013, 10:56
  4. ARB and suspension choices recommendations
    By dunk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2008, 01:01
  5. suspension choices
    By eski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th April 2007, 18:39
