Well I've got the turbo now, but it needs more work than I thought, there is minimal play in the shaft but large cracks around the waste gate and the intake compressor has bent blades
Where can i get replacement parts from? Are there any upgrade options available while its in bits?
This turbo sounds scrap tbh. It'll be iro 400 or more for a new / recon I reckon. New hotside, compressor wheel , bearings and seals , assembly and balancing as a minimum requirement to fix yours.
True but you will never learn anything getting "others " to do it, from his first post he wanted to have a crack at it himself, but if its cost saving, i agree it would be better to buy one already done, as balancing is not cheap..
