EM TuningSky Insurance
Thread: Headlight bulbs
    Jan 2014
    south wales
    92
    Headlight bulbs
    Just wondering what headlight bulbs are best by looking the a3 has projector headlights ? So is it safe to use hid bulbs If so are they h1?
    thanks
    Feb 2006
    Lincolnshire
    713
    You need to check, on my old A3 they were H7/H7 main/dipped, although many online checkers said they would be H7/H1.
    And yes, HID bulbs will be fine in those projectors with the usual caveats around legality and some folks insistence that there is a difference between HID and Halogen projectors.
    My old A3 kit consisted of the usual ballast but with D2S leads from the ballast to the bulb. I purchased some D2S to H7 converter plates from eBay USA which enabled me to run some decent Phillips 4300k D2S bulbs.
    In my current S3, as one of my OEM ballasts went wrong, I've installed a 50w kit also using D2S bulbs, but this time 5000k for a bit more whiteness. I find anything towards 6000k a bit blue for my liking.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Jan 2014
    south wales
    92
    Ok thanks they just look really dull compared to standard headlights really yellow it may just be the the bulbs they are h1 from what I can see!
    Midlands
    310
    Could be the lenses also, they split and appear yellow.
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    Jan 2014
    south wales
    92
    Also thought lenses any way of cleaning them? Cheers
    A3 TQS
    Jul 2013
    Devon
    158
    I'd go with osram nightbreakers if you want to stay halogen, better output than regular bulbs and are whiter looking and as for restoring the headlights, wet and dry and a polish brings them up well, depends how far gone they are really, I had to go down to 600 and then followed with 800,1200,1500,2000 then rubbing compound and then a final polish with srp.
    Before
    After
    Headlight Restoration (With Pics)
  1. Headlight Bulbs
    By reynot01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th June 2005, 21:55
  2. What headlight bulbs??
    By imported_bayliss in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2004, 18:25
  3. Hellfords replacement headlight bulbs
    By ActionJackson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2004, 07:11
  4. headlight bulbs - help required!
    By ultramodz in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2003, 12:02
  5. Civic Headlight bulb removal??
    By Naresh in forum Other Brands & Models
    Last Post: 26th June 2003, 13:12
