Monster MotorsportChris Nott
Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By 16Klappe
Thread: Quick Q: Are top mounts actually bolted on?
    Nov 2011
    Leeds, UK
    287
    Or do they sit sandwiched between the metal plate on the top of the spring and the metal plate that bolts on the top in the engine bay?
    Sounds daft, but I have just been putting a new shock together and the centre bolt went through the top mount. I was sure that wasn't supposed to happen but thought I would check before getting upset!
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,012
    Visit 16Klappe's Instagram Channel
    No.
    Yes.
    newbster likes this.
    I quite often say I'm going to do things.
    Then never do them.
    Jan 2014
    Worcester
    183
    The weight of the car stops them from moving, they aren't bolted in
    Edit: sorry thinking about a different car, I'm wrong here
    Nov 2011
    Leeds, UK
    287
    Thanks guys, really worried there. I've never had a car with top mounts like these which aren't bolted onto the shock itself. I knew they didn't bolt to the car, but was worried they should still bolt onto the shock itself.
    So the bolt on the strut, does that bolt on the metal plate above the spring AND the bearing that the top mount then sits over?
    Nov 2011
    Leeds, UK
    287
    Just to clarify, this is the strut assembled. Bearing at the top below the nut.
    The top mount just sits over that nut, it isn't fixed on by it?
    Jan 2012
    Kilmarnock, Scotland
    333
    That's not right. The nut holds the top mount on
    Nov 2011
    Leeds, UK
    287
    Well not these LCR ones it doesn't? The nut went straight through the middle when I was tightening up and now sits over the bolt....
    A3 TQS
    Jul 2013
    Devon
    158
    Click the pic
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Looks like the top plate is upside down...
    the plate is like a top hat... bearing on top of that, then the top mount rubber and a flattish nut... insert through hole in suspension turret, fit top plate and larger nut
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    According to that diagram, it must be meant to be sandwiched between the nut and the bearing, as I originally thought.
    I was tightening up that shock without compressors on initially and have obviously torn through the middle due to not thinking first.
    It really has been one of those days.
    Feb 2006
    Lincolnshire
    713
    There are two nuts involved.
    One goes above the bearing and holds the spring top plate and spring tension.
    The top mount then sits on top of that, and sits up into the suspension turret on the car, and then the top cap is bolted onto the strut top to hold everything in place when the car is jacked up etc.
    The lower nut on my car is thinner than the one in your pic though.
    edit: there was a post frenzy whilst I was typing!
    The mount isn't sandwiched between the nut and the bearing, at least it isn't in any meaningful way. The main thing is that you get the spring plate and bearing right up against the end of the threads on the strut, otherwise it will knock.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Nov 2011
    Leeds, UK
    287
    Erm....
    I was trying to use the nut on the right!
    Been a lonnnnngg day!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Quote Originally Posted by Bad Sir Culation View Post
    Erm....
    Larger flat one first dude lol.... (and I know the feeling :P)
    <tuffty/>
    Nov 2011
    Leeds, UK
    287
    Given up for tonight. The top nut with the Konis is actually 22mm too, so can't use the 21mm socket with an Allen key through it
    Mar 2013
    Devon
    558
    You have the spring cap the right way in your pic, you just need to remove the Koni nut, add the top mount, and then add the 21mm slim nut (VAG refer to that nut as a threaded retaining bush).
    If you have access to an impact gun, it's a far easier way of tightening the final 22mm Koni nut.
    Nov 2011
    Leeds, UK
    287
    Sure do, one one the electric ones though.
    I'm reluctant to use an impact gun as I'm worried about idamaging the shock.
    Mar 2013
    Devon
    558
    You wont damage the shock with an electric impact gun, do this day in day out.
    You can reach inside the gator and hold the shock shaft with one hand and then gun the nut up, then a final check with torque wrench.
    Nov 2011
    Leeds, UK
    287
    Hmm... I will try but not sure I can really hold shock shaft through these H&R springs. I could maybe use grips with a rag to protect the shaft but still not comfortable with it.
    Jan 2012
    333
    Don't hold it with grips. You should be able to get a hand on it. They don't generally need a lot of holding. Thumb pressure should be enough
    Mar 2013
    Devon
    558
    Don't use grips, very easy to damage shock shaft. If you cannot do it by hand go back to the old school methods.
    A deep cranked ring spanner with hex bit socket through middle will normally work. Or if you ultra flash the vortex hollow ratchets and sockets work a treat.
    Nov 2011
    Leeds, UK
    287
    Just realised, I have a 22/24mm deep cranked ring spanner from Halfords that I never thought I'd use and meant to take back but forgot!
    I'm very paranoid about damaging new suspension, and don't even like jacking under the arm and compressing the shock and spring, even though common sense says not to worry lol.
  1. Are the top mount bearings difficult/awkward to replace?
    By Garlo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th August 2013, 16:35
  2. S3 Top Mounts
    By Sandip in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2008, 21:28
  3. we are top of the league....erm championship
    By voorhees in forum General Chat
    Last Post: 3rd September 2007, 03:38
  4. Replacement Rear Top Mounts
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2006, 23:24
